Hood Insulation
Old Mar 14, 2008 | 02:09 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Hood Insulation
Hey all,
I got a new IROC hood for my 91 RS and I was looking at my old hood insulation and noticing that it looked like crap, and I wouldn't want to move it over to the new hood. My question is, does it actually serve a purpose? What effects will it have if I run the new hood without the insulation?
Thanks in advance,
-Tim-
Old Mar 14, 2008 | 02:47 PM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Re: Hood Insulation
A little more noise outside the car & your hood will be a little warmer when you drive. Thats all I can think of.
Old Mar 14, 2008 | 02:49 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: Hood Insulation
And probably louder when you shut it. Although, my 87's hood was sort of "loose" between the layers, so that might have contributed to it. But I really noticed a loud metal SLAM when shutting it sicne I removed it. The 86 I got still has new insulation...and its nice and quiet. Like the doors shutting.
J.
Old Mar 14, 2008 | 06:49 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
Re: Hood Insulation
it also protects the paint from getting to hot from engine heat... but again most camaros ive had were missing it and id didnt seem to hurt them at all...
Old Mar 16, 2008 | 01:22 PM
rocco 87's Avatar
Car: 87' Iroc Z-28
Engine: 5.0
Re: Hood Insulation
that stuff does nothin but keep unnescessary heat inside. cause if you think about it there isnt much other places for the hot air to escape except through there. if you have it installed it has to escape through the underside of the car. granted during the winter it will run a lil cool but these cars were designed to run to hot so a lil dip in temp wont hurt.
Old Mar 16, 2008 | 08:00 PM
spiderhole's Avatar
Car: 86 z28 LG4 305ci
Engine: LG4 305ci
Re: Hood Insulation
How do you remove the black plastic tabs without destroying them?
Old Mar 16, 2008 | 08:55 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Re: Hood Insulation
I also had crappy hood insulation and removed it and replaced it with some from NAPA but I plan to paint the under side of the hood with heat resistant paint soon to make it look cleaner. You could do that if you don't like the crappy looking insulation. For the week that I when with out insulation it was a bit louder but I barely notice and my car black so the hood couldn't get hotter then it get all the time from sitting in the sun. To the thing about that stuff does nothing but keep unnecessary heat inside I pretty sure that if your car is like mine that it is open at the back of the hood and heat escape there over the windshield. What IROC hood did you get?
Old Mar 16, 2008 | 09:30 PM
Car: 1991 Camaro RS
Engine: L98 350 TPI
Re: Hood Insulation
It is just an aftermarket IROC replacment hood... My standard flat hood had a baseball bounce off of it up near the windshield, and then last year I got into an accident and that folded the front passanger corner down... Rather than fix the flat hood, I just bought an IROC one... It was at least the same price (if not cheaper) than the body shops quote to fix the flat hood
Anyways, thanks everyone for the input. Looks like the hood insulation isnt actually all that necessary.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
