Fog Lights
Old Mar 14, 2008 | 10:17 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Fog Lights
I bought the Sylvania 880st, and I looked at the stock one....... no idea how to take it out or put the new one in. The regular head lights were easy to install but these fog lights I dont get.
Old Mar 15, 2008 | 06:27 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: Fog Lights
there should be a retaing screw on each side the the foglight. take those out and pull the 2 black trim peices out then the foglight should slide out with no problem and u can unhook the lights from the plug and put the new ones in. i dont think there was any change in the folights form an 88-92. they r rectangle right?
Old Mar 15, 2008 | 07:06 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: Fog Lights
yeh, they are rectangular.
I took the fog light out of the glass box [dont know what its called] and It doesent have a plug, it looks like 1 wire is soldered on to the back of the light and then theirs another wire from the car going to the actual glass box [looks like a ground]
The new fog light I got which is what they said at the store I would need for my car has a plug on the back, the stock one looks like its just soldered on or something.
And those screws are hard as heck to get too, I think I striped it, lmao.
Old Mar 15, 2008 | 07:09 PM
Engine: Vortec 357
Re: Fog Lights
the wire coming out of the foglight should run into a plug under the bumper or somehwerre that u can undo and on mine theres a retaining clip on the back holding the bulb in.
Old Mar 15, 2008 | 07:18 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: Fog Lights
Yeh theirs a clip holding the bulb in. I took that off and took the bulb out, but I just couldent figure out how to take the bulb off its metal base.
Plug under the bumper?
i just got 2 wires, no plug anywhere. The foglight I bought has a plug and I just dont see where I plug it in at.
Old Mar 15, 2008 | 07:33 PM
Engine: Vortec 357
Re: Fog Lights
follow the red wire that attaches to the bulb. eventually u will run into a plug unless someone cut it out and just sotered the 2 wires together. if thats the case cut the wire and put a u clip on the end. if i can take some pics and ill be able to tell u what to do from there
Old Mar 15, 2008 | 07:39 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: Fog Lights
Yeh ill take some pics and show you later today or tomorrow what it looks like. I only looked at the passenger side, maybe the driver side is different or something.
But on the passenger side its just 1 wire on the back of the light and that goes through some metal sheet. The other wire comes from through that metal sheet also and is connected to the metal in the back of the glass box, doesent even touch the light.
Its always simple little things like replacing this fog light that seem to give the most problems, hah hah.
But the Sylvania silver star headlights look great!
Old Mar 15, 2008 | 10:48 PM
Engine: Vortec 357
Re: Fog Lights
lol ok ill check back when you get some pics posted so i can see more with what im dealing with. mine were pretty simple but now i gotta do it again as i hit black ice and slid into a snowbank at like 35 ****ing up mydriver side foglight and bumper corner. Oh well car needs work anyhow lol
Old Mar 15, 2008 | 11:41 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: Fog Lights
Well if ya get to it before me, take some pics!
I think even though its late as heck ima just go shower and watch some TV, then go take the fog lights out and take pics for ya.
Thanks for the help though!
Old Mar 16, 2008 | 02:53 AM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: Fog Lights
Alright well I jacked the car up, and looked back there.
It runs back to an adapter way back in there and it doesent fit the new fog lights
I guess if I can find the right plug and just wire it in I would be all good. But it doesent look like the light even fits in the glass box!
Attached Thumbnails Fog Lights-dsc02602.jpg   Fog Lights-dsc02603.jpg   Fog Lights-dsc02604.jpg
Old Mar 16, 2008 | 02:55 AM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: Fog Lights
Heres some more pics to show ya what im talking about. Sorry they kinda suck, Its cramped under that car, hah.
Old Mar 16, 2008 | 08:32 AM
Engine: Vortec 357
Re: Fog Lights
sylvania does make an aftermarket bulb that will fit in there and they are bright as hell. idk if u have Napa's in virgina but i found the bulb u need to fit it and the part number is LMP BP880BK. now that part number may be universal. and really all u need is power and ground to run that bulb so if u can slipce into the exsisting wires that would be great and then either ise a bigger clip or just glue it to the back to the light lol. In most cases u can get them to fit it just takes some hard thinking and grunt work. If u need anything else just let me know
And ill try and get some pics of mine up so u can see how mine is mounted, wired ect.
Last edited by TADailyDriver; Mar 16, 2008 at 08:33 AM. Reason: Automerged Doublepost
Old Mar 16, 2008 | 11:08 AM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: Fog Lights
Alright, thanks man. Ima unlpug it and splice them into the back of the bulb, then just use hot glue to hot all that together, then ima just get under the car, figure out how far back it has to be to fit in the glass box and hot glue it in place. Then put the glass box on and move on to the other side.
Old Mar 16, 2008 | 11:31 AM
Celticsfan's Avatar
Car: 1985 Trans Am
Transmission: 700-R4
Re: Fog Lights
pics would be great i need to upgrade my fog bulbs too
Old Mar 16, 2008 | 11:38 AM
Engine: Vortec 357
Re: Fog Lights
Those foglight bulbs r so bright u can almost run with just those on and no headlights lol
(will get pics as soon as weather gets warm, so prolly monday or today even if i have the motovation lol)
Old Mar 16, 2008 | 12:04 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Re: Fog Lights
ok cool how much do the bulbs run? i just got the fog assemblies because the old ones were red/blue car was a dare car haha
Old Mar 16, 2008 | 12:06 PM
Engine: Vortec 357
Re: Fog Lights
i picked up the bulbs for like 12 dollars at a local napa but thats becaus emy buddy has a garage account and gets discounts. But retail on them is like 26 bucks for a pair i think.
and where did u get ur assembiles at? i shattered my driver side assembly after hitting a snowbank and need to get a new or used one with the retaining plate
Last edited by TADailyDriver; Mar 16, 2008 at 12:07 PM. Reason: Automerged Doublepost
Old Mar 16, 2008 | 12:08 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Re: Fog Lights
damn thats huge difference, any clue what temp they are like 4000k? cuz i could probably get them cheap on ebay
Old Mar 16, 2008 | 12:10 PM
Engine: Vortec 357
Re: Fog Lights
im not shure ill have to fin the packgae that they come in. (Im a pack rat and save everything i buy for my cars so when it comes time to sell them i have all recipets and packages lol) But ill def let u know or if i cant find it ill stop in at the local napa and ask to see the box
Old Mar 16, 2008 | 01:22 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: Fog Lights
I got 1 of the 880st's in. Looks great
i just put it in the assembly, hot glued it in place, wrapped electrical tape around it. Cut a little out of the back of where the assembly goes into the car, and it fits. On the passenger side it sticks out a tiny bit now due to the bulb pushing in the back. But you cant even really notice.
Oh yeh and spliced the wires and connected them to the back of the light. Replacing those bulbs next time should be alot easier.
With my sylvania ST head lights it all looks great. very white and bright.
Old Mar 16, 2008 | 01:41 PM
Engine: Vortec 357
Re: Fog Lights
Awsome! post some night pics when u get a chance. would love to see them in action!
Old Mar 16, 2008 | 03:27 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Re: Fog Lights
damn i was in walmart and checked out the prices for the sylvania h3s they were 19/bulb...figured it would be cheaper there
Old Mar 16, 2008 | 03:48 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: Fog Lights
Yeh my old bulbs were h3's I think. But i wired up the 880's and it works.
Ill post some pics of how they look.
Old Mar 17, 2008 | 09:25 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: Fog Lights
Heres how they look!
Attached Thumbnails Fog Lights-dsc02611.jpg   Fog Lights-dsc02610.jpg   Fog Lights-dsc02612.jpg
Old Mar 17, 2008 | 09:45 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: Fog Lights
The reason that bulb doesnt fit is because its not made for a firebird fog light.If you look at the old bulb and the new one they are totally different.The original bulb is held on by a wire which connects to a spade plug inside that mesh wrap.All you do is pull it out and it should slide back in when you replace them.I dont think the bulb can just be replaced as ive always cracked them trying to get them out.You have to get the whole piece with the wire on it.The sylvania bulbs you got will however fit camaro fog lights from 85-97 without a problem.
Old Mar 17, 2008 | 09:56 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: Fog Lights
Yeh, the bulbs were totally different. But as you can see from the pictures I just used some hot glue and tape to hold it in and wired it up and its working : )
Next time ima get the right bulbs though, H3's I believe. Its gonna sucks cleaning all that hot glue out though
Old Apr 6, 2008 | 03:46 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Re: Fog Lights
did you get a chance to find the number?
Old Apr 6, 2008 | 07:13 PM
Engine: Vortec 357
Re: Fog Lights
wow soory completely forgot to look, got to busy packaging and shipping parts. I will look tommmrow i promise.. i know the package is out in the barn.
Old Apr 6, 2008 | 10:22 PM
userchemical's Avatar
Car: 1984 Camaro Z28
Axle/Gears: 4th gen auburn 3.42 disc
Re: Fog Lights
looks good keep up the good work.
Old Apr 6, 2008 | 10:27 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: Fog Lights
They are a lot brighter and whiter then the ones it had on there before.
What kinda lights you running?
Old Apr 6, 2008 | 10:36 PM
Re: Fog Lights
nothing right now lol, my car is in the middle of being restored. Not sure what im going to do for fogs. I haven't decided just getting some ideas.
Old Apr 6, 2008 | 11:09 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: Fog Lights
Oh, lol. I find the fogs almost pointless, I only got them on for the coolness of how they look.
Old Apr 6, 2008 | 11:14 PM
Re: Fog Lights
i like using them when i run into fog. lol
Old Apr 6, 2008 | 11:20 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: Fog Lights
We barely get fog and my headlights do just fine at nighttime and in fog, I just always have my fog lights on with my headlights so I can look good in my ******* mobile for the ladies, lol.
Ive heard that yellow is more visible in the fog anyway.
Old Apr 8, 2008 | 10:36 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Re: Fog Lights
Wow, you guys are waaaay off on this one. The bulbs cannot be removed from the harness that they are seated on. What you really needed for an exact fit was the Sylvania H3 or H4's. They come in 55 watt and 100 watt combinations and they are about $5 each.
You can also use the Cyber Whites from Wal-Mart at 39.95 for a set, which include the housings which are almost a direct fit for the 'birds.
JB.
Old Apr 9, 2008 | 01:35 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Re: Fog Lights
pretty sure its h3s for the fogs h4 for headlights...
Old Apr 9, 2008 | 04:58 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: Fog Lights
Its H3 for fog lights im pretty sure and 880's for the headlights.
Old Apr 9, 2008 | 08:02 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Re: Fog Lights
Negs. H3 and H4's are for the fogs only. I think the headlights are still sealed beams.
JB
Old Apr 9, 2008 | 08:20 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Re: Fog Lights
sealed beam as in the bulb is sealed in the housing or the housing it self? I picked up a nice hella housing w/ the bulbs, there pretty nice...
now i just need fog bulbs and put the lights in the car
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
