Rear Quarter Panel Rotted
Old Apr 7, 2008 | 12:56 PM
ShaunCx1477's Avatar
Hey guys just wondering what would be the easiest way to do it your self repair the rear quarter panel? Its rotted along the wheel well. Me and my dad can do all the body work so its pointless having someone else to do it. Just wondering if you guys had any ideas? Thanks guys
Old Apr 7, 2008 | 04:40 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Rear Quarter Panel Rotted
how bads the rot? if its really bad you may want to buy a new 1/4 skin and section in where the old one is rotted.
Old Apr 7, 2008 | 06:53 PM
EH82Z28's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 305 TBI
Transmission: 700-R4
Axle/Gears: 10 Bolt, 2.73 open diff
Definitely get a new skin if it is very bad at all. Remember the rule that if you can see the rust on the outside it is at least 6 inches in all directions on the back side.
Old Apr 7, 2008 | 09:39 PM
HottestZ28's Avatar
where can you get good skins?
Old Apr 8, 2008 | 07:06 PM
EH82Z28's Avatar
Engine: 305 TBI
Try year one or the paddock. They should have what you need
Old Apr 8, 2008 | 08:08 PM
Iroc'nthe87's Avatar
wouldnt u have to cut and weld the 1/4 piece back in?
Old Apr 8, 2008 | 10:51 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
what do you mean by the 1/4 piece? you could just order the new skin and cut the sections out that are bad on your car then cut these same sections out on the new 1/4 and weld em in.
Old Apr 9, 2008 | 06:00 PM
EH82Z28's Avatar
Engine: 305 TBI
Don't just cut the sections off of the skin and weld them in, unless it is a really small area. You will have it all warped and won't be happy at all if you have no experience doing body work. If you only have a small area to do, like the wheel lip, then they sell patch panels specifically for the areas that always rust. You will be much happier if you skin the whole quarter. It is not that much more work and will be less hassle in the long run .
Old Apr 9, 2008 | 08:28 PM
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
Do you have pictures? You can also get quarter skins from classic industries ($85 each) If it's minor you can just cut and shape sheet metal then weld it on and shape it more with a body hammer. I would recommend replacing the whole thing though, I've seen guys get new quarter skins and get it painted just to have the rust come back 2 months later. If you have body experience you should know how to swap a quarter panel, it's pretty straight foreward
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Exxon Limited
Aug 9, 2015 08:13 PM
z28addict8490
Aug 7, 2015 08:48 PM
