bondo
Old Mar 16, 2008 | 02:48 PM
Hartmann's Avatar
bondo
has any tried to use that on their ground effects or the body? i need to repair some of my ground effects. i also need to repaint my iroc camaro air dam piece on the front that says camaro. it was their after all even though the foglights are gone but the camaro is almost faded how would one get the camaro white again? stencil and rattle can?
Old Mar 16, 2008 | 03:40 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
Transmission: Built 700R4 w/ 2500 stall
Axle/Gears: 3:73 posi
Re: bondo
i dont know what your damage is that u need to repair but just remember, bondo not for anythign structural at all and will crack very easy. Use fiberglass or some epoxy to do the repair and then put on some bondo as thin as possible to get everything smooth.
Old Mar 17, 2008 | 08:01 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: bondo
go to wally world and get some plastic weld- comes in the black tube in the paint isle buy the duck tape
use that to glue it back together. dont worry that stuff is kick a$$
get some polyester glazing puddy to shape the ground effect
you should be out less than $20
Old Mar 17, 2008 | 09:38 AM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
Re: bondo
for all my repairs to ground effects or any small dents that cant be pulled i just use fiberglass filler and take extra time to get it smooth. This way it dries hard as a rock. My dad rebuilt a cab corner on my old truck with fiberglass filler and it was just as hard as the sheet metal that was once there. Also you couldn't tell by looking at it either. -Matt
Old Mar 17, 2008 | 10:21 PM
EH82Z28's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 305 TBI
Transmission: 700-R4
Axle/Gears: 10 Bolt, 2.73 open diff
Re: bondo
Definetely don't use putty to fix cracks. Use a fast setting epoxy on the back side. Set some fiberglass matting down (or drywall seam tape, it works the same), then put a layer of epoxy down. Slightly "v-out" the front side w/ a die grinder and put a thin layer of epoxy down. If that is not enough to fill the crack in the front, put down a skim coat of a polyester finishing putty such as Icing.
hepcat620
Exterior Parts Wanted
Aug 30, 2015 07:52 PM
silentneko
Feb 12, 2002 10:21 PM
CaliCamaroRS
Feb 6, 2002 12:33 AM
Thirdgenfbody.com
Jun 12, 2001 06:28 PM
