HOOD VENT REMOVAL
Old Apr 13, 2008 | 11:31 AM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
HOOD VENT REMOVAL
How do you remove the rear vents from a '91 TA stock hood? I can see the nuts that hold the front 2 vents through access holes, but I cannot find any hardware holding the rear pieces in place. Do they just pop out or pry out (with care)?
Mine are down to primer in places and need to be refinished. I would rather do them off of the car but I suppose I can mask and paint on the car if I have to.
Thanks for any advice.
Old Apr 13, 2008 | 12:01 PM
racerx520's Avatar
Re: HOOD VENT REMOVAL
yes the rear ones do just pop out pretty much and yes the front ones do have speed-nuts that hold them down, but unless you take a dremel or a hole saw to them to widen up the hole for the 5/8 socket (i think thats what it is atleast) then you have to go at it with a pair of needle nosed plyers and just inch it out....it'll take youa a while
Old Apr 13, 2008 | 09:40 PM
tavert91's Avatar
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Thanks. I'll try to gently push them out tomorrow.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Wife'sCar
Aug 22, 2015 01:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
3rdgenparts
Aug 8, 2015 07:09 PM
