bent subframe?
Old Apr 22, 2008 | 03:07 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
bent subframe?
I've been getting my car up on jacks often. I've noticed all these places where someone has jacked the car up and bent what i believe to be the subframe. What should I do about these pieces?
Drivers side front
This is harder to see but it's bent in the middle like an upsidown U(front passenger side)
Old Apr 22, 2008 | 06:42 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Re: bent subframe?
Ya could pull it, or weld another piece to make it flat, just make sure ya rust-proof it --I have the same thing
Old Apr 22, 2008 | 06:46 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: bent subframe?
is this a big problem? Would the "right Way" be to pull or weld a new piece on? what thickness should the new piece be?
Old Apr 23, 2008 | 08:37 PM
TheBigJ's Avatar
Car: 85 Firebird
Re: bent subframe?
Well my word may not be the best word out there (? everyone else) but I think you should pull it, if you decide to do anything about it... looks like it may have bent the frame a bit? I wouldn't do anything if I had a choice and it was my car
I'll look at my car here tommorow and see how hard it would be (gotta sand it down again for final)
Old Apr 23, 2008 | 10:23 PM
crazydave's Avatar
Re: bent subframe?
Nothing to worry about. It is caused by people jacking car up without using a block of wood to spread the load. Sharp edges on jack pads are usually the culprit.
Old Apr 24, 2008 | 09:42 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: bent subframe?
I think I'm going to weld in some plate. What thickness should I use?
Old Apr 29, 2008 | 12:19 PM
RaGiN Z's Avatar
Car: 83 Camaro
Engine: 383 stroker, mini blower, nitrous
Transmission: TKO600
Re: bent subframe?
I think you are looking for more trouble than its worth. Especially considering where you are looking to weld. I would leave it be, its not a big deal. You are only going to introduce rust into the scenario.
Nervous2
Oct 8, 2015 10:53 PM
tmork454
Sep 29, 2015 06:33 PM
Zell1luk
Sep 29, 2015 10:36 AM
ccop
Convertibles
Sep 14, 2015 04:13 PM
