Gold Firebird Graphics Removal?
Old May 8, 2008 | 03:19 PM
New3ra's Avatar
Car: 82 T/A 47,XXX
Engine: 305 until the ZZ4 355.
Transmission: turbo200
Axle/Gears: 3.42's
I have an 82 T/A with the gold graphics along the bottom, is it possible to remove this without damaging paint underneath...
Im not a fan of the gold and as long as It can come off clean im doing it!
Old May 8, 2008 | 04:05 PM
userchemical's Avatar
Car: 1984 Camaro Z28
Axle/Gears: 4th gen auburn 3.42 disc
Re: Gold Firebird Graphics Removal?
yes it is. get yourself a razor blade, goo gone, wd-40 and a pillow to sit on. Now very carefully remove them with the razor using the wd-40 as lube. dont press to hard or will will dig into the paint. you just want to slide under the graphics. Use the goo gone to remove whatever adhesive is left. Then you are going to want to wax your car so you cant notice the fresh white paint under the graphics.
Good luck.
Old May 8, 2008 | 04:44 PM
intruder's Avatar
don't usew a razor blade one slip and you'll get the paint go get a heat gun
Old May 8, 2008 | 05:10 PM
if you do that, be careful not to burn your paint.
Old May 8, 2008 | 05:28 PM
JohnC's Avatar
Car: 1988 IROC-Z
+1 on the heat gun. After you get it off, there will be residue left over, and then use goo gone.
Old May 9, 2008 | 02:01 AM
gordo420's Avatar
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
+2 on the heat gun and paitence
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
theshackle
Aug 22, 2015 06:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
