Factory Paint code help
Old May 17, 2008 | 03:46 PM
RoadHammer's Avatar
Car: 1991 Camaro Z28
Axle/Gears: stock
I need help in finding the factory correct Black paint code for 91-style Hood blister inserts, door handles and locks.
This is for my 91 Z28.
Thanks.
Old May 23, 2008 | 11:39 PM
irocman79's Avatar
Car: 1989 Iroc Camaro
Engine: Stock 350 TPI
Re: Factory Paint code help
If color of your car is black than they should be the same color as you car. and that code should be in in your glove box. There is lots of info on this on the site for decoding the tag in the glove box
Old May 24, 2008 | 09:53 PM
RoadHammer's Avatar
Axle/Gears: stock
Perhaps I should have been clearer.
I am talking about the little "grille" insert-thingy (for lack of better terminology) in the blister itself.
Old May 25, 2008 | 07:19 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
There isn't really a code for the black trim. I found the Duplicolor Trim Black is almost a dead on match. I resprayed the rear window louvers with this and found it to be very close. I would think that SEM or or others would have an exact match of just "Trim Black"
Old May 26, 2008 | 02:29 PM
RoadHammer's Avatar
Axle/Gears: stock
I'll try that. Thanks
Old May 27, 2008 | 12:17 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I use SEM, its really close. I find that it is slightly more flat than the OEM but after a few years of rubbing it looks like the OEM stuff. So I really don't know if the age of the paint indicates that it is worn or the SEM is not as glossy... I like the SEM because it sticks really well and it covers well..
Never tried the Dulicolor so I can't argue with Scott...
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
ken3983
Aug 23, 2015 07:31 PM
