Pin on hood question
Old May 17, 2008 | 09:42 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
I want to buy a cowl induc hood but i dont wanna sped 400+ so i found a pin on 3 in for like 287 on summit if i bought that is there a way to hook up the hinges like drill holes and use hood pins? thanks in advance for any help
Old May 17, 2008 | 10:06 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: Pin on hood question
I`d like to know as well.
Old May 18, 2008 | 08:15 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
there is no place to mount the hinges on a pin on hood. if you look under your hood now where the hinges attach you will see what i mean. on a pin on hood the area where the hinges would attach are flat versus on a bolt on/stock hood there is a "mounting panel" i guess you would call it.
Old May 18, 2008 | 08:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
^ a pin on hood is VERY lightweight and lacks most if not all of the underside ribbing in which the hinge mounts would be located. You cant use them with the hinges, no way no how, thats why they are sooo cheap, they are thin and rather flimsy actually. Even if you rigged something up to mount the pin on hood to the hinges, the hood is most likely not strong enough to support its own weight from just the lower end and it will most likely break.
save your pennies for a bolt on hood, its a real PITA having to lift off the entire hood all the time when you want to check something and also having to find somewhere to put said hood where it wont blow away in the wind.
Save for a bolt on hood
Old May 19, 2008 | 05:56 AM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
ok i was jsut wondering if you could like pin the hood to the hinges but from what you said it wont work thanks for the info so i didnt buy one and try. they are just the cheapest ones i can find.
Frozer!!!
Jan 19, 2024 04:55 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
bryan623
Aug 10, 2015 11:33 AM
