How many hood bumper stops are required?
Old May 24, 2008 | 04:30 PM
Burro's Avatar
Car: 1992 Z28
I've purchased a 1992 Z28 that had a bolt on (dzus fasteners) fiberglass cowl hood. I'm installing a factory hood, and I need to put on the hood bumper stops. The car had none installed, so my question is how many do I need?
Also, I've only found these for sale on Hawk's
http://www.hawksthirdgenparts.com/in...OD&ProdID=1555
Do local parts stores normally stock these?
Thanks in advance!!
Nick
Old May 24, 2008 | 04:59 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: How many hood bumper stops are required?
I want to say I have two and I would think a local parts store would stock these, not sure though.
Old May 24, 2008 | 05:03 PM
Stephen's Avatar
Car: 87 GTA
Same here......
Old May 24, 2008 | 11:02 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
I've got 4....2 up front and 2 more close to the windshield. The back 2 are on the bases of the hood hinges and I'm pretty sure theres a notch on each side in the bottom of the hood that catches under the rubber bumper when I close the hood.
Old May 24, 2008 | 11:11 PM
Burro's Avatar
Car: 1992 Z28
thanks for the help!!
Old May 25, 2008 | 07:50 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Pick them up.. hold them chest high, then drop them...
Hi Nick! Good to see you joining your third gen brothers!
(I have 4 total, the rears are all jacked up)
The front 2 are like the ones you posted, the rears are part of the hinge as mentioned before.
Old May 25, 2008 | 08:35 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
ya the rear ones are just bolts with plasticy rubbery covers. you have to rembove the plastic covers to adjust the bump stops. at least on mine you do.
colton_carlson
Mar 8, 2019 12:21 PM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
SlowAZ28
Sep 2, 2015 05:19 AM
