Installing trans am rocker panels?
Old Jun 11, 2008 | 09:54 PM
moxley110's Avatar
im putting trans am ground effects on my firebird. i got the quarter panel GFX on, and the front/rear bumpers on. but how the hell do i put on the rocker panels? i have the rockers, the brackets, and the door panels. but im completly lost here.
any help is appreciated!
Old Jun 12, 2008 | 09:07 PM
moxley110's Avatar
Re: Installing trans am rocker panels?
anyone?
Old Jul 25, 2008 | 07:37 PM
moxley110's Avatar
i reall yneed help on this, these panels are the only thing keeping me from repainting the car, and the local autobody place cant get me in till next year to put em on, so id rather do em now.
Old Jul 25, 2008 | 07:53 PM
moxley110's Avatar
oh, and i forgot to mentiont hat i dont know how to attach these brackets to the actual plastic panel, and whatnot.
Old Jul 25, 2008 | 08:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
there should be a metal bracket that runs the length of the rocker that need to be welded to the car, then the plastic part attaches. then there are holes that need top be drilled in the fender and quarter for the lower plastic piece.
Old Jul 26, 2008 | 12:12 AM
moxley110's Avatar
yeh, i know that much, but the panels are 20 years old, and the brackets may be bent, i've never seen em before, or know how. there isnt a trans am i can look at in town and know.
i need pics, if anything, or i may make a very big mistake tomorrow.
Old Jul 26, 2008 | 12:45 AM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
Time for you to improvise and innovate. I had the same problem and here is what you can do.
What I did was to use some curtain brackets and thresholds for doorways. Screwed the curtain brackets on where the holes for the GFX meet and put the thresholds on top of them fastened by some small nuts and bolts. I put them roughly about a 1/4" below the level of the door to give the GFX enough room to clear the door. Buy yourself some 3M double-sided tape (the kind for GFX) and stick the front and back of them to the car. Remember that the rear part of the GFX screws into the car so that one will be just fine. The front you can always screw down also if you invent.
I took those same curtain brackets and flatened a couple out. Screwed one side to the GFX and the other side to the car. Yes, they were all straight and sturdy. If you could've got a good set of the original spot-welded brackets then you are in business. You can use some self-threading screws to put them back onto the car. Screw welding. Of course, you can devise your own way.
Old Jul 30, 2008 | 03:36 AM
moxley110's Avatar
could sometome just open the door and take a pic of where the rocker panel connects to the body?
Old Jul 30, 2008 | 07:24 AM
camaro_boy123's Avatar
Car: 1986 Camaro z28
Engine: 350 v8
im not sure if your weldind these in? i do hope you are because there really is no strength without welding. Regardless, Line the new rocker up and drill holes every say a ft and pop rivet the rocker in place for alignment. After that tack weld it. Remove the rivits and weld the holes shut. Thats how i would do it to make sure its lined up. also you can find out exactly where the original spot welds were when you take off the old rocker. Make it, check it and check it again and then drill it. Check twice drill once!
hope this helps
Old Jul 30, 2008 | 09:08 PM
moxley110's Avatar
that does help, but my probelm is, is that i dont know where the bracket actually goes, cause im fairly sure the guy bent it when her packaged it, and rocker panel itself is a little warped, so i dont know where or how it goes onto the side of my car exactly, like if it overlaps the body, or goes flush, or if i have it upside down :S
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
