door handle busted
Old Jun 20, 2008 | 07:12 AM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
door handle busted
my driver side outside door handle just succumbed to the added stress of opening caused by saggin hinge pins.
i can only open the door from the inside. when i pull the inside handle the outside handle still rotates upward like normal.
what is the best way to help fix this?!?
thanx
Old Jun 20, 2008 | 08:53 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Re: door handle busted
I replaced mine about a week ago. I thought mine was just loose, but when I got it off it fell apart in my hand. It's easy to fix. Just remove the door panel, remove the rod going from the handle to the latch, and then remove the handle (two bolts). While the door panel is off, go ahead and lubricate everything in there too. If I can fix this anyone can. LOL
Old Jun 20, 2008 | 09:17 AM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
You can pick up a new door handle on ebay for about $15-20 including shipping.
Old Jun 20, 2008 | 06:31 PM
Car: 1986 IROC-Z28
could i swap it with the passenger in the mean time?
thanx yall
Old Jun 20, 2008 | 07:11 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
I'd just leave the passenger one alone and go to your local parts store and buy a door handle, shouldn't be more then $15
Old Jun 20, 2008 | 07:49 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Watch out for the ones at O'Reilly's and Advance, they may look the same but the holes don't match up for f-bodys. They're meant for other GM cars like the Century and Celebrity. I bought mine off ebay for $12.
Old Jun 20, 2008 | 08:28 PM
EvilCartman's Avatar
Car: '82 Z28
You can't swap them side to side like you can the interior handles, the spot where the rod goes would be wrong. I bought a replacement at the local Napa, the fit was fine but the quality really isn't there.
Veaceonee
Sep 29, 2016 08:15 PM
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Buggy Disaster
Sep 17, 2015 05:12 PM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
