removing door protecter
Old Jul 10, 2008 | 06:57 PM
91rs5.7tpi's Avatar
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
i was wondering how do you remove the thing under the door handle that goes all the way to the fender that protects the door from getting hit. will there be holes after its removed? im just wondering because it makes the cars look 100% cleaner
Old Jul 10, 2008 | 07:04 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Re: removing door protecter
no there will not be any holes under the stripe. Its just held on by some adhesive or 2 sided tape.
Old Jul 10, 2008 | 07:05 PM
91rs5.7tpi's Avatar
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
so would it be easy to remove. should i use a heat gun to do it or what?
Old Jul 10, 2008 | 07:29 PM
stroked_n_blown's Avatar
Car: '92 Camaro RS
Engine: 305 TBI
Transmission: Richmond Gear street 5 speed
You can use a heat gun to soften it, or you can get a special tool from Classic Industries that slides underneath it, cutting the adhesive from the body. Any place that deals in restoration probably has them. If you don't want to buy it, just take a look at theirs in the catalog, you might be able to fab up something similiar
Old Jul 10, 2008 | 07:56 PM
91rs5.7tpi's Avatar
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
alright thanks guys
Old Jul 10, 2008 | 08:28 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Fishing line.....it's that simple. Start at one end and slip the line under the tip of the guard. Work the line up and down kinda like a saw. Usually when you get about 8-10" loose you can just grab it and peel it the rest of the way off. Rubbing alcohol works good to get the adhesive residue off without taking off the paint.
This method also works great on emblems, dealer tags, and whatever else is stuck on using double sided tape.
Old Jul 11, 2008 | 01:37 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
I agree with FYRCHKN, fishing line, welding wire, string, basically anything like those will work fine.
and just for the record, on some thirdgens these strips were riveted on, but that was I think up till 84.
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
Street Lethal
Aug 13, 2015 08:28 PM
BrianI
Aug 9, 2015 11:52 AM
3rdgenparts
Aug 8, 2015 07:09 PM
