Flared rear fenders...
Car: 87 GTA
Ignore the overall car (it's not mine) but I'm thinking about getting the rear fenders.
Yes, I'm asking for opinions, but let's let be nice here, OK? It's just as easy to say "Not for me/Not my style", or just NOT post at all, as it is to start spouting garbage & insulting, OK?
They'll give a 2" bulge, which is what a 4th gen rear axle is....wider than a 3rd gen axle. My tires sit virtually flush right now. So combined with these hand-laid fiberglass fenders & a 4th gen axle, they'll sit flush again, & easily allow them to be widened 2"! More if I wanted, but I don't see much point in more than a 11" wide 17" wheel. 12" would probably be pretty much the max, for a useble sized wheel.
Car: 1984 Camaro Z28 T-tops
Re: Flared rear fenders...
I think it would look really good, but you would have to use wider wheels and tires to fill up the extra space, or else it would just look goofy.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
IMO if you do the rear fenders, you'd need to do the fronts as well, or it would look goofy
Car: 87 GTA
I'd have my wheels widened & a 4th gen axle ready to bolt in, before those fenders went on, so I wasn't stuck running narrow tires with those fenders for any amount of time.
Car: 1987 Trans Am
Engine: 355
Transmission: t56
I think it'd look really good all done (with the new rear and widened rims), I say go for it!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Neil extended his rear quarters to fit 18x12 with 335's, his were done with steel, cutting and bulging the rear, though i think they were a little more than 2", maybe 3"?. These glass ones would do pretty much the same thing, i dont think they would look bad, so long as they were installed properly and blended to the body. Are they even still available?
Car: 87 GTA
They are available....$600 for the pair.
I thoughgt about Neil'd method. I like it better, but with the way my GTA tail lights look like 1 wide piece of formed shiny plastic, there would be 2 gaps, that would hafta be filled somehow. Not to mention the cost...I inquired about doing them & only the outer sheet mtal, no inner work like Niel got.
Let's just say...$$$$$$$$$$$....It ain't gonna happen without me winning the lottery!
I realize you said it would allow you to run the wider rear, wheels and tires. It was my way of agreeing with you. Maybe I should have been a little more clear.
Car: 87 GTA
I see them as an a way to keep the Snypers I have....
not having to buy new wheels for a different offset...
and not to hafta mini-tub the car.
I wouldn't bond the fiberglass to metal. Metal and fiberglass expand at different rates as temperature changes and they will separate/crack. Fabricate something inbetween maybe something like what the 4th gens do for sail panel to rear fender? Other than that it would be cool. The concept Camaro does a similar thing with widened rear(or perhaps it just appears that way) http://www.seriouswheels.com/pics-20...-1920x1440.jpg
The 85-90 t/a side and rear ground effects might not work on these fenders which means you may have to go with a 82 or 84 rear bumper. You wouldn't have that problem of rust in the rear fender, ever.
Here is a link to some pics with this kit or similar kit on this thread:
https://www.thirdgen.org/forums/hist...en-racing.html
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
A wide body bird.....
Thats would be sweet man. I mean, it's not like its been done many times before. I think by the time you filled out the wheel wells with bigger rolling stock it would give a much more subtle appearance.
Car: 87 GTA
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
true, but i dont wana do this to my car for one thing . 2nd stephen and I talk and want not ,and he know what im talking about....( was talking to him on aim when I posted that)
bla bla bla
so are they on yet? hmm if you do this and the lm7 you will have some fun....
bla bla bla
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Donations welcome!
