Removing Carpet, Found Crack...
Old Jul 20, 2008 | 07:35 PM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Well as the title says, I was taking the carpet out of the back half of the car in preparation to fix any rust I may find and start sound deadening and I found this :
It's along the weld, which looks more like glue... but is there a way to fix this? Not that it'll rust, not now that I baby her. But would like to take care of it while I have it open like this. Thanks!
Old Jul 20, 2008 | 07:47 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Removing Carpet, Found Crack...
Have you removed that caulking material.I dont think your floorboard is cracked though, but just to be sure remove that stuff.If you know its not cracked then just apply some new sealant.Thats all that stuff is to seal the inside form the outside.Also have you checked from the outside.In the wheel well.If its the metal/weld the crack will show on the other side.Looks worse than it is, im guessing.
Old Jul 20, 2008 | 08:09 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I have been thinking about a rear shock tower brace
let us know if there is any cracking after removing the seam sealer
Old Jul 20, 2008 | 09:25 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
rear shock brace, is there one for 3rd gens?
Old Jul 20, 2008 | 10:03 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
[QUOTE=Fyrstorm;3829801]Well as the title says, I was taking the carpet out of the back half of the car in preparation to fix any rust I may find and start sound deadening and I found this :QUOTE]
Dang, by what you posted I expected to read the you found some drugs oh well, I guess a crack and crack are one in the same
Old Jul 20, 2008 | 10:11 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
That made my day, Iron Duke ... freakin' hilarious ... cause I was thinking the same thing. I just knew this dude found a rock from the 80's. LOL.
Don't want to get off topic, but a friend of mine in college found a bag of weed in a recliner he got from the Salvation Army Store.
Dude, that crack shouldn't be hard to fix.
Old Jul 21, 2008 | 06:56 AM
Fyrstorm's Avatar
Car: 86 Trans Am
Thanks for the input everyone! I didn't even realize the alternative meaning of the title lol Guess it made ya look
I had no idea they bothered about caulking the welds on the inside, now that I know it's not an indication of something major I won't fret much about it hehe!
I did find a business card, the keytag from the used car dealer I got it from, and two pennies. One 1986 and one 1987, I'll be putting those back under the seat when I reassemble
Old Jul 21, 2008 | 11:01 AM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
I don't think it's a crack, that small piece is spot welded in and sealed with seam sealer. My guess is the seam sealer has separated from the sheet metal. They did an article on this area in GM High-Tech Performance.
Attached Thumbnails Removing Carpet, Found Crack...-0805gmhtp_12_z-rust_separate.jpg
Vintageracer
Jan 10, 2020 05:33 PM
lee01
Apr 9, 2016 01:56 PM
bjpotter
Aug 12, 2015 06:06 PM
3rdgenparts
Aug 8, 2015 07:09 PM
antares57
Aug 6, 2015 07:47 AM
