orb of power vacuum ball
Old Jul 21, 2008 | 11:05 PM
eddie jr's Avatar
the vacuum ball under the front left fender well (below battery tray)...........how does it actually attach on, does it attach to a bracket or just to the battery tray itself? I am swapping to factory cruise and am wondering if i need to get a bracket to mount it.
thanks.
Old Jul 22, 2008 | 09:04 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Re: orb of power vacuum ball
I can take pictures if you want, it attachs right through and onto the cruise unit above. That is on my 85 firebird, my 91 seems a bit differen't tho
Old Jul 22, 2008 | 09:12 PM
AC's Avatar
AC
Car: Used to drive a camaro
There are tapped tabs if you will on the driver side of a camaro and provisions on the pass side also. If you're using the pass side you'll need clips simliar to the ones (not the same size) that attach the fenders. You can also just use a nut,washer, bolt to fasten it as well, just don't crank down on tightening and you won't crack the plastic.
Old Jul 23, 2008 | 01:31 AM
eddie jr's Avatar
That would be cool if you could. But attaches to the cruise unit on an 85? Or are you referring to a carbed car? I just realized that, battery is on the passenger side........but i still though 85-up all had the cruise module mounted on the fender beside the washer tank?
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
mdtoren
Aug 23, 2015 12:52 PM
InfinityShade
Aug 22, 2015 08:00 PM
mdtoren
Aug 16, 2015 05:45 PM
