How in the heck do you adjust this???
Old Aug 17, 2008 | 06:37 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
Just put a new rear deck lid on my Firebird, it came off a Camaro...I didn't think there would be any differences.
I got the bolts loosened and I pushed as far as it will go....that's where it stops
Old Aug 17, 2008 | 06:47 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Re: How in the heck do you adjust this???
Damn, that's a big gap . Have you removed the lower panel from the glass? If not, you're going to need to. I went through it a couple a months ago, it's aggravating. You'll need to scrape off all of the black goo between the glass and the metal panel.
Here's my thread on it...
https://www.thirdgen.org/forums/body...alignment.html
Old Aug 17, 2008 | 08:17 PM
Car: 1971 Camaro
Hey thanks, I figured it out....it helps to unbolt the struts so you don't the resistance of them kicking the decklid back
Old Aug 17, 2008 | 08:40 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Good job my friend!
How ya gonna fill&redrill the holes for the rear qtr.gfx & door pieces?
Since you plan on installing newer front fenders they should be of no worry,but the other panels still need attention.
Old Aug 17, 2008 | 08:45 PM
Car: 1971 Camaro
Originally Posted by TIMMYS89GTA
Good job my friend!
I may hit the local pull a part next weekend and pick some solid doors, mine have slight hail damage anyways.
I noticed yesterday the holes didn't line up on the rear....I'm going to just weld in some small pieces of sheet metal and put some filler over it.
Shame that I'm dropping a 305 TBI engine in the car, it has the full performace supsension (ws6, think that what it's called)...rear disc brakes, bigger sway bars ect....I think the previous owner put a subframe brace or something under the car....something looks different under there.
Maybe after I get the car done I'll look at dropping in a better engine
Old Aug 17, 2008 | 08:53 PM
dude!look at my photobucket album highlighted below!I did a half a**ed 305 tpi in my car after all that body work and am now building a new 350 for her.
Do yourself a favor and get what you want for an eng. now instead of after you get the rest of the car done.
Old Aug 18, 2008 | 01:16 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
