T Top Problem
Old Aug 30, 2008 | 04:25 PM
'86 Camaro BoSs's Avatar
Car: 1992 Camaro RS - 1971 Chevelle
Engine: 3.1L - 5.7L
Transmission: T-5 - TH350
T Top Problem
ok, it's been discussed a million times on here, i searched and couldn't find an answer to my question..
about 2 month's ago my '92 camaro's Lexan T-Top flew off, so we went out and bought a glass t top that fit.. or so i thought, i tried adjusting the places where the t top's lock into on the car, but there's still a very small gap on the back part of the t top, and i was looking and noticed that the plastic part of the t top doesn't go flush with the rest of the car when it's on and i can see a hole there. can i do any adjusting, or do i need to just get another t top?
p.s i've tried on 2 t tops from 2 different cars..
Old Aug 30, 2008 | 04:50 PM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Re: T Top Problem
maybe you bought the wrong size pinned t-top? Theres two different types of t-top pins that hold them on. Check and see which one you have. If you have the small one its just a little metal pin driving into the t-tops. if you have the large pin its a small pin with a large plastic cover on top of the metal pin and its usually for later models. 1896?-1992. I had lexan covers also and bought some glass ones and reamed out the hole with a drill to make it match/fit and used the old assembly from the lexan one to the glass ones to to make it fit. I haven't yet put it all together bu i will when the car is painted./finished.
But before I tried putting the small pinned one into my big pinned hole and there were some seriously different gaps.
Old Aug 30, 2008 | 05:46 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: T Top Problem
With the tops locked in can you wiggle them? Let me guess... It was the passenger side that flew off....
Old Sep 1, 2008 | 10:51 PM
Engine: 3.1L - 5.7L
Re: T Top Problem
It's not a problem with the pin's.. the pins and the holes they attach to.. it's hard to explain over a computer.. there's a gap with the plastic piece.. the t tops fit nice and snug.. and it was the driver side that flew off.. the front pin decided not to go out when i closed it..
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
theurge
Aug 21, 2015 12:46 PM
Fronzizzle
Aug 9, 2015 01:15 PM
