Blinkers dont blink
Old Nov 9, 2008 | 01:32 PM
SLOWMARO355's Avatar
Blinkers dont blink
84 camaro. My turn signal lights come on when I chose left or right, but they dont blink.
What could be the problem?
No bulbs are blown!
Old Nov 9, 2008 | 01:49 PM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Blinkers dont blink
No bulbs are blown!
my 92 had the same problem and strangely all i did was clean out the bulb sockets and it fixed the problem not sure y but u sould start there
Old Nov 9, 2008 | 01:59 PM
Stephen's Avatar
Car: 87 GTA
If the dash light comes on, and stays lit, but the outer lights don't actually flash, that is could be an indication that one of the bulbs outside are blown. Some relays also use the super rapid flash pattern, to indicate a blown outer bulb.
That's all I can think of, as to why a dash light would come on & stay on.
Old Nov 9, 2008 | 04:52 PM
rodrob1961's Avatar
Car: 2003 SILVERADO /86 IROC/85 S10
DO YOUR 4-WAYS WORK?
Old Nov 9, 2008 | 04:53 PM
What are 4 ways?
Old Nov 9, 2008 | 06:54 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
sounds to me like you have a bulb that is burnt out. turn on your 4 ways (AKA hazards), and your head lights and look for the bulb that does not blink. keep in mind it could be the turn signals mounted in your front fenders.
Old Nov 9, 2008 | 07:10 PM
DJ Delsym's Avatar
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Well I hope your key is in the on position but pick up a new flasher (cheap) and/or check the fuses.
Old Nov 9, 2008 | 07:40 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Turn each bulb a bit to knock the corrosion off the inside of the socket.. Happens every once in a while to me.
Old Nov 9, 2008 | 08:29 PM
Ill try that. Those bulbs were never in.
Old Nov 9, 2008 | 08:34 PM
Yes, they blink. I'm missing the two bulbs in the fenders. Ill try that and see what happens.
Old Nov 9, 2008 | 08:39 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
yea go for the flasher.......i think the 4 way and turn signal is a seperate flasher....side markers wouldnt cause that, but replace them they are there for a reason
Old Nov 10, 2008 | 12:12 PM
I went out this mornin and started the car, and my right blinker worked, then the left blinked fast, then they just stopped.
Alright, All bulbs have been removed, cleaned out. There was no corrosion.
I replaced the side marker lights. Flashers have been changed.
Still no blinker.
Old Nov 10, 2008 | 04:50 PM
89RS_82Z's Avatar
Still no blinker.
hmmmmm so you go just a steady burn when you turn them on, 4 ways work properly flasher have been replaced.......... i had a problem on our motorhome that the turn signal blinked normal, but when you hit brakes it got faster, and if you were hitting brakes and the parking lights were on it would be even faster, turned out to be a bad ground, but it also had the wrong size bulb in it two (it aslo has amber turns in the back) but it took a single contact, if memory serves me correct our amber turns in the back have a dual contact, dual filliment bulb, why i dont know they dont use the marker light (dim) part...should be a 1157NA the NA for amber tinited glass so make darn sure you got the right bulb, and if that still dont work, maybe rerun a new ground wire......other than that i got no clue
Old Nov 10, 2008 | 05:03 PM
Run ground wire from?
Old Nov 10, 2008 | 05:29 PM
89RS_82Z's Avatar
run a wire from the ground wire on the plug to a good piece of clean metal
that help??? need more????
Old Nov 10, 2008 | 05:32 PM
From the marker light wire?
Old Nov 10, 2008 | 05:37 PM
89RS_82Z's Avatar
no it would have to be the ground on one of the turn siginals not the side marker....the side marker actually grounds to the (+) of the front turn siginal, that is how it flashes with the turn siginal but also functions as a side marker
but im thinking that it may not be a ground issure since the 4 ways work and the fact that its both the left and the right that dont flash when in the turn mode......unless you got a bad flasher, try moving the 4 way flasher to the turn siginal flasher and the surn siginal flasher to the 4 way...... see what that does
im getting and it aint even my car, lol i had to see how you feel
Old Nov 10, 2008 | 05:54 PM
I see a flasher on the right. Its a spot for one on the left, the two I have are the same. They dont fit on the left. Under that is a green box(Left)White(right) and the annoying buzzer thingy below it.
Is the one missing my problem?
Old Nov 21, 2008 | 11:16 PM
Regal105's Avatar
Car: 83 c10, 2015 silverado
Engine: 454, 5.3
Transmission: Turbo 35o, 6l80
Axle/Gears: 3.42, 3:23
I have the same problem with my 90' rs, it happens rarely but it's a pain in traffic, gotta flick the lever up and down manualy
Old Nov 22, 2008 | 03:20 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I think that means you have a loose wire somewhere. When it does that you should make sure all your blinkers are working.
Old Nov 23, 2008 | 01:37 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
If the 4 way flashers work, then the bulbs, wires, grounds and everything else in the circuit are good. A fuse or flasher would be my first check, then move on to the turn signal switch in the steering column.
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
Tyler-88
Oct 28, 2001 11:08 AM
BahamutRS
Sep 15, 2001 02:51 PM
Jimmy91RS
Sep 28, 2000 02:16 PM
