NEED FRONT AND REAR BUMPERS
Old Dec 1, 2008 | 11:27 AM
racerquinny's Avatar
Car: 91' camaro rs and an 87' trans am
Engine: stang eater..slower ones. lolololol
Transmission: 700r4-camaro t5-trans am
Axle/Gears: stock :(
i got a 91' RS black. does any one know where i can get them. i tried the junk yard found one. but couldnt get bumpers off. or if anyone is restoring one and has two available.
thank you
quinny
Old Dec 1, 2008 | 12:11 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: NEED FRONT AND REAR BUMPERS
look in the parts section on this board.
Also, why couldnt you get the one off at the j/y?
Old Dec 1, 2008 | 08:51 PM
well i got the bolts off of the rear bumber. but i didnt have the right tool to get of 3 rivets or bolts couldnt tell what it was. so i left the car and went home before we got stuck there. becuase it was snowing.
Old Dec 2, 2008 | 03:08 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
where are u located, i have both off an 88 iroc z28 that are black, already removed
Old Dec 2, 2008 | 03:14 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
there should only be 3 bolts on each side and license plat cover bolts and I think 1 bolt on each side that connects the rear gfx to the bumper, but if interested I have a 82-84 z28 bumper for cheap
Old Dec 3, 2008 | 07:14 AM
Dale's Avatar
Engine: 350 S-TPI
rear bumper...
you have 3 10mm bolts on each SIDE in the cargo area.
You have to remove the tail lights (10 wing nuts)
You have 2 10mm bolts for the license plate
You have 6 plastic snaps up top
you have 5 plastic snaps on bottom.
you have 2 small screws that hold the rocker gfx to the bumper.
Then if you need the metal bumper, you have 8 13 or 15mm bolts.
front bumper gfx(91-92 model)...
countless 10mm bolts going to the nose piece
4 metal clips to the fender
2 screws in fenderwell
front nose after gfx are gone...
4-5 10mm nuts each side bolting to the fender (these suck getting to)
8'ish small screws to remove the tray or dual snorkle depending upon model
8-10 10mm bolts to undo brackets under tray/snorkle
2 bolts and 4 clips to undo wind trays on underside (if still there)
6-8'ish plastic clips on bottom side going to metal bumper
Old Dec 3, 2008 | 07:36 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
for the original poster, please be aware that your bumpers are specific to 1991 and 1992 only. The rear bumper cover is absolutely not the same as earlier years due to the fact that the ground effects changed for 91 and 92 and they are molded as one piece with the rear bumper cover. The front ground effects are a separate piece, so the front bumper cover might be the same as 85-90, but you'll have to confirm that with someone more familiar with Camaros (I know more about the firebirds). I'm almost certain that the front bumper cover was different for 82-84 though.
Old Dec 3, 2008 | 04:07 PM
ok..so will the earlier years fit. or wouls i just have to do some custom work to have them fir snug.
Old Dec 4, 2008 | 03:51 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
I think I described it pretty well, with the exception of not knowing if 85-90 and 91-92 front bumper covers are the same excluding the bolted on ground effects. "fit" can mean a lot of things to different people. If you mean will it bolt up and possibly look like crap, than sure.
I'll try to do Cliffs Notes for you. If you want an exact match to the original bumper covers than you need a 91-92 rear bumper cover. In the front you can definitely use a 91-92 front bumper cover including that bolted on ground effects and you MIGHT have the option of using an 85-90 front bumper cover and bolt your existing ground effects to it.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
MORREALE5
Sep 13, 2015 09:16 PM
