Quick door handle question
Old Dec 1, 2008 | 10:04 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
My outside drivers door handle is loose a flops up and down, but i can still open the door. can i just buy a whole new handle and will it work?
This is what im looking at getting and wondering if it will fix it. http://www.ecklerscamaro.com/product...dept%5Fid=1445
Old Dec 1, 2008 | 10:18 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Quick door handle question
You can do that or you can find another door handle at a junk yard from any s10 or s15, don't know the year range, or any firebird or camaro, 82-02 (yes 4th gen included)
Old Dec 2, 2008 | 06:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The flop is caused by a broken spring (lift up on the handle and you may be able to see it). If you pick up one from the JY, make sure the spring is in intact as most will be broken.
JamesC
Old Dec 2, 2008 | 06:54 AM
vette gator's Avatar
Car: 85 Z28
I picked up a replacement at Autozone. Putting it in wasn't the most enjoyable job with my big hands. One tip I found after I finished the job was to cut real threads on the studs with a die rather than using the self-cutting nuts. I had some trouble getting the self-cutters to "bite" and there isn't much room to work. Real threads probably would have been a lot easier.
Old Dec 2, 2008 | 07:32 AM
JamesC's Avatar
There are pics/diagrams in the following link that might prove useful:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Dec 2, 2008 | 06:47 PM
rodrob1961's Avatar
Car: 2003 SILVERADO /86 IROC/85 S10
I DID THE SAME THING ONLY, I PUT THE SELF TAPPERS ON TO CUT THE THREADS BEFORE I INSTALLED THEM AND THEN TOOK THEM BACK OFF. CUTTING THE THREADS ON THE WORKBENCH FIRST SAVED ME A LOT OF TIME IN THE END.
Old Dec 2, 2008 | 09:37 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
thanks for the info guys, dont know what id do without TGO. For 10 bucks ill just get the whole new handle!
Old Dec 3, 2008 | 09:38 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
I had the same problem with the bolts that come with the door handles, I just put another bolt on one of the studs after getting too tired and annoyed... hope I never have to take that handle off again because that bolt probably won't come off! but hey... "cross-thread is tighter"
Old Dec 6, 2008 | 12:27 AM
Camaroguy6984's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI L03
Transmission: TH700R4 Corvette servo
Axle/Gears: 10Bolt 2.73
I replaced my driver side like 2 years ago with a new 3rd gen style, wasnt the worst thing I ever did, but this past summer its broke AGAIN =( so im thinking of doing the 4th gen style door handles, i just dont know what they look like on a 3rd gen and havent seen pics or noticed them in pics on here, so if anybody has pics i would be very gratefull to you for posting them.
Old Dec 17, 2008 | 08:24 PM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
I bought 2 new ones from Ecklers but ended up refinishing my originals as they were better quality, mine weren't broken just faded out.
Old Dec 17, 2008 | 09:41 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
they're the same thing, 4th gen ones just don't have the indent for the stickers so they're smooth. I beleive MN_formula did his...
Frozer!!!
Jan 19, 2024 04:55 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
