fixing space between hood and body on a 1990
Old Dec 7, 2008 | 12:17 AM
a1990camaro's Avatar
Car: 1990 RS tbi camaro
Engine: 5.0 tbi stock, hooker headers
any know if i need to replace the hood latch or something so the hood sits level on the body of the car..because my damn hood has about a 1/4 in-1/2 in. space between the hood and body.........also the hood has problems opening i have to pull the hood latch while holding the hood down sometimes...... all i want is that damn hood to close perfect!
Old Dec 7, 2008 | 05:01 AM
kcb37's Avatar
Re: fixing space between hood and body on a 1990
Open the hood and in the corners you should have to rubber bumpers, turn them down and see if that helps.
Old Dec 7, 2008 | 11:57 AM
bigbird89's Avatar
Car: 86 Firebird
Also, the hood latch itself can be adjusted if the rubber bump stops don't do the trick. In my experience, the hood latches need adjustment over time, but with a little experimentation, you shouldbe able to get it right.
Old Dec 7, 2008 | 01:00 PM
popballz's Avatar
Car: 89 firebird
mine was like 1/2 inch too high, and all i did was move the latch all the way down,
if it still needs to go down more, then try to move the whole piece of metal the the hood latch is connected to, there might be a little wiggle room.
and on a firebird, you can pull the middle of the bumper up a little too.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
neekolzun
Aug 24, 2015 04:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
