t top seal change ?
Car: 1992 camaro rs
t top seal change ?
ok so ive searched and found one diagram but not very helpful i ordered new t top seals the ones that sit over the window when its closed my driver side is ripped well anyways i went to chance took off plastic cover and the handle to pop the t top out.and can see the seals but cant figure out how to get out with out ripping the rubber seal that the window presses against when its closed please someone help me.
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Re: t top seal change ?
If you a referring to the rubber seal on the t-top, mine have all been glued in from the factory.
Car: 1992 camaro rs
and how do i get the screw out that hold it in? thats what i mean i cant figure out how to get screws out to take old one out and im only replacing 1 seal not both
Car: 1991 RS Camaro
Engine: 350 0.060" over
When I did mine one of them had glue so old that it slid right out. On the other one I destroyed the old seal in the process of removing it. Once th seals were out, the screws under them were exposed and came right out.
1992 Trans Am
May 10, 2023 07:19 PM
Thornburg
Aug 25, 2015 01:46 AM
Dialed_In
Aug 20, 2015 01:45 PM
Zachattack0925
Aug 12, 2015 09:52 PM
