Rusty Fender - Help
Old Dec 3, 2008 | 01:46 PM
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
Rusty Fender - Help
I want to repair this fender since I got a parts car for this reason and I need to learn anyway. The one bolt I had to grind off and there are like 2 small rust holes. How would I go about repairing this? What about the clip where the bolt is? The rest of the fender is in perfect shape and the one on my car now would not really be repairable. I hit a stop sign from sliding and it also bent my mirror.
Old Dec 3, 2008 | 07:25 PM
robster66's Avatar
Engine: 305 T.B.I.
Re: Rusty Fender - Help
Anyone?? What do I need to get and what is the process?
Old Dec 3, 2008 | 08:39 PM
robster66's Avatar
Engine: 305 T.B.I.
I was reading online and took a grinder to it which removed some of the rust but there were spots I couldn't off and holes started popping up? How do I go about this?
Old Dec 3, 2008 | 09:32 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
cut out the rot and weld in a patch. I hope you don't plan on using the fender because welding on fenders will usually warp them unless your very careful.
Old Dec 4, 2008 | 12:06 AM
robster66's Avatar
Engine: 305 T.B.I.
I plan on using it lol
Old Dec 4, 2008 | 05:58 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
haha then I'd say be very careful or could you get pics of the damage? if its just little pinholes you might get away with applying rust converter then fiberglassing it.
Old Dec 4, 2008 | 06:17 PM
robster66's Avatar
Engine: 305 T.B.I.
I going to take more pictures tomorrow but I cut out a square. I don't think I can do this because as I uncovered some paint it looks like the whole bottom part is rusted and I can't bend sheet metal like that lol
Old Dec 4, 2008 | 07:01 PM
robster66's Avatar
Engine: 305 T.B.I.
Since there is rust from top to bottom is there a way I can cut, weld and bend sheet metal to do this?
Old Dec 4, 2008 | 08:19 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
How come none of your pics ever work for me? I wanna see!
Old Dec 4, 2008 | 08:31 PM
robster66's Avatar
Engine: 305 T.B.I.
god damnit maybe thats why no one is posting back lol!! I am hosting it off my computer it should be working that makes no sense.. Ima host it from imageshack for now and than try and figure out why its not working.
Old Dec 4, 2008 | 08:37 PM
robster66's Avatar
Engine: 305 T.B.I.
After I got to it messing around and cut a square out of it even though the whole bottom half has to be replaced.
Old Dec 5, 2008 | 12:58 PM
slia67's Avatar
Dude,
That fender just needs to be replaced!
Old Dec 5, 2008 | 02:10 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Yup that thing is done. Finding clean fenders isn't exactly hard.
Old Dec 5, 2008 | 02:11 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Your best bet for that would be to replace it. Second best would be to find another fender with a decent bottom on it, cut it off and weld it to the one you have. At that point though, you might as well just replace it with the fender you found.
Old Dec 5, 2008 | 02:26 PM
burn0ut305's Avatar
Car: z28
Transmission: pro built 700r4 (road racing kit)
just get a new one, its not worth ur time.
Old Dec 9, 2008 | 02:46 PM
robster66's Avatar
Engine: 305 T.B.I.
I got this one from the junkyard it needs new brackets but I will do that in like a year lol. I just sanded it now I have to prime it and slap it on
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
aaron7
Sep 30, 2015 09:15 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
