Will An 85 Trans Am Front fender fit on an 84 Trans Am?
Old Dec 11, 2008 | 12:21 PM
91RS84TA's Avatar
Car: 1991 Camaro RS/ 1984 Trans Am
Engine: 305 V8 TBI - 350 Swap In progress!!
Transmission: 700-R4
Axle/Gears: STOCK
I have an 84 Trans Am and the front fender is weathered from the previous owner (bondo & peeling paint). I don't like the look of the fender besides the fact that i can't recognize what year it belongs on. It looks like a modified 83' Daytona front. Now finding a Daytona front I believe is impossible but I love the front end of the 85-90. I wanted to purchase one from Hawks but wanted to be sure if it would work with the 84 body as a switch. Open to all/any advice.
Old Dec 11, 2008 | 08:27 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Will An 85 Trans Am Front fender fit on an 84 Trans Am?
Im Sure that any 3rd gen year firebird fender will bolt onto any 3rd gen firebird. Up to you to see the differences in GFX mounting points, Fender vents, etc.
And, 82-84 T/A's are the best. I have an 84.
Old Dec 16, 2008 | 05:48 PM
recarosp's Avatar
Car: 83 Recaro TA/ 95 TA
Engine: 355 / LT4
Transmission: turbo 350 / 6 speed
Axle/Gears: 373 / not sure think same
THE TOP BOLT HOLES ARE DIFFERENT JUST NEED TO ADJUST WITH EATHER A HAMMER OR SHIMS
Old Dec 16, 2008 | 08:18 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
I did that on my daughter's '84 car in my signature. The 85-up ground effects come up higher on the body. If you change the nose, you'll want to swap all the gfx & fender vents including the rear bumper cover for it to all line up. If you just replace the fender you will have 5 holes to fill on the '85 fender and re-drill the lower '84 TA gfx holes.
customblackbird
Aug 15, 2021 10:16 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
kyleb24
Aug 15, 2015 08:24 AM
TheJoeY88
Aug 13, 2015 06:51 PM
Amillionoh7
Aug 7, 2015 01:24 PM
