Attaching rear spoiler
Old Jan 4, 2009 | 10:44 AM
GT150's Avatar
Car: 1988 IROC-Z
Transmission: 5 speed
Axle/Gears: 3.08 posi
I am about to put my spoiler back on. When I took it off for painting it was bolted directly to the body. Does anyone know if this is correct or was their some kind of seal between the spoiler and the body to protect the paint.
Mike
Old Jan 4, 2009 | 11:04 AM
blg0720's Avatar
Car: 88 GTA
Engine: 305 V8 LB9
Transmission: 4 sp. Auto-4L60
Re: Attaching rear spoiler
There should be some sort of gasket around the base to protect the interior sheet metal from rain and other moisture. Otherwise, your hatch will rust out.
Old Jan 4, 2009 | 11:07 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
mine was direct bolt on . when i re-installed i made sure to put sealent around stud base on spoiler . this should prevent any water leakage . i went maybe a little overboard , i removed all studs , cleaned same , light coat of epoxy , re-installed studs . let epoxy cure for 24 hrs. , then installed . good luck .
LilHot
South Central
Apr 13, 2026 11:46 PM
colton_carlson
Mar 8, 2019 12:21 PM
LilHot
Exterior Parts for Sale
20
Apr 1, 2016 04:45 PM
LilHot
Aug 19, 2015 10:02 AM
AkDrifted
Aug 17, 2015 07:45 PM
