molding bumper with rocker panels
Old 01-04-2009, 10:02 PM
chevylove87's Avatar
Car: 87 camaro
Transmission: 700r4 shift kit
i was wanting to mold the rocker to the bumper and i was wondering if i should worry about any cracking or anything like that if anyone has does this can i see pics?
Old 01-04-2009, 10:55 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: molding bumper with rocker panels
Maybe you should describe that a different way. The rocker panels are between the wheels and the bumpers are on each end of the car. The wheels are really going to get in the way.
Are you talking about the ground effects? Or the fender? Either way cracking would be something major to consider.
Old 01-04-2009, 11:05 PM
Car: 87 camaro
the peices on the rear quarter panel molded on the rear bumper to make it look like the front how it wraps around you know
Old 01-04-2009, 11:22 PM
Car: 86 T/A
Engine: 5.0 TPI
Much better! I think you'd have better luck doing the rear than anything on the front... less chance of hitting a curb and less wind hitting it too. If you weld the seam with a plastic welder it would be good and strong. Just doing an adhesive repair with a urethane or epoxy plastic repair product would probably eventually crack or get so thick that it would never look right. Although if you reinforced the back of it and didn't get the outside to thick it would probably look ok. It's possible ... do your homework.
Old 01-05-2009, 07:32 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
If you decide to do it your best bet would be to fiberglass it. Bondo WILL CRACK. I'm pretty sure fiberglass will end up cracking too.
Galaxie500XL
02-01-2020 04:53 AM
Mutillator
Exterior Parts for Sale
01-02-2016 06:44 PM
New2Chevy
09-28-2015 12:35 AM
tglennon11
09-23-2015 05:30 PM
Stryker412
09-07-2015 09:11 AM
Quick Reply: molding bumper with rocker panels
