1984 antenna removal
Old Jan 9, 2009 | 05:36 PM
S10GUY's Avatar
Car: VR6 jetta for commuting
Engine: VR6
Transmission: 5spd ZF lsd
Axle/Gears: ?
Is it possible to remove my antenna with out removing the fender?
Old Jan 9, 2009 | 05:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 1984 antenna removal
You can take out the inner fender liner and reach in behind the fender.
Old Jan 9, 2009 | 06:26 PM
userchemical's Avatar
Car: 1984 Camaro Z28
Axle/Gears: 4th gen auburn 3.42 disc
very clean look
Old Jan 9, 2009 | 06:40 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yea its real easy, all I did was just remove all the stuff up top and just push n shove the post down and over. Then fill the hole. I still pick up station just fine.
Old Jan 9, 2009 | 07:27 PM
S10GUY's Avatar
Engine: VR6
Axle/Gears: ?
wow im really special i never thought of pulling the inner liner! thanks alot
Old Jun 19, 2009 | 08:27 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Which inner fender liner? In the wheel well, or under the hood? And will I be able to feed the wire of a new one this way?
The base on mine is broken and the antenna wobbles really bad, I want to just replace it with the short rubber kind like I had on my first firebird.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
scottmoyer
Sep 7, 2015 07:06 PM
Stryker412
Sep 7, 2015 09:11 AM
84 TA NV
Sep 6, 2015 08:02 PM
rjcme
Sep 5, 2015 01:23 PM
