Door Swap?
Old Jan 19, 2009 | 02:44 PM
84z-28's Avatar
Door Swap?
ok recently me and my dad swapped out the passenger side door of a 84 Z28 for a 89 RS. We replaced the hinges and bushings for the bottom only and finnally got the door back on yesterday......but when we went to shut it, it wouldnt close all the way and felt like it was rubbing up aganist the ground effect but we really couldnt tell. the only way we can get it to shut all the way is if we put some elbow grease into it and shut it with all our might.......any ideas on why it is so difficult to shut? thx
Old Jan 19, 2009 | 05:48 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Door Swap?
sounds like the upper pin/bushings are shot.
http://www.top-downsolutions.com/pro...&reviews_id=63
Old Jan 20, 2009 | 09:25 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: Door Swap?
Did you have the window up or down when you were trying to shut it? Definately start with the window down so it isn't part of the problem. Then you need to see how far it closes before it hangs up. Look closely and see what doesn't line up. There has to be some clue somwhere. Is it aligned to the 1/4 panel both up and down and in and out ... at the top and the bottom. Does the body line half way up the door panel match up with the 1/4 panel? Doors can be a pain... windows can be worse. But it's all doable.
Old Jan 21, 2009 | 03:58 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
Re: Door Swap?
sounds like its out of alignment, no matter how much it looks the same....no to parts are, could be the top hinge is wore out, open the door and pick up and down on it, if it moves alot u need a hinge rebuild
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
