Did the T-Tops ever change throught the years?
Old Jan 25, 2009 | 12:39 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I have the opportunity to but a set of the lexan (plastic) T-Tops and was wondering if the tops or mounting points changed at all? I don't believe they ever did but as the tops would be bought mail order I can't test fit them to confirm.
Thanks,
Robert
Old Jan 25, 2009 | 01:07 PM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
Re: Did the T-Tops ever change throught the years?
Only change I'm aware of is the pin/post size. I've seen them referred to as small post/pin, and large post/pin.
Disclaimer
I am not an athority on the subject so wait for someone you trust to know to confirm or deny this.
Old Jan 25, 2009 | 07:44 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
True, plus the 82-83 cars had a latch instead of pins. And then...the C&C tops were a bit shorter in length.
Old Jan 26, 2009 | 12:30 AM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
my car came with lexan tops that had the "large" pins. had a little mishap and one blew out well a friend of mine gave me, thats right gave me a set of glass ones but they were "small" pins. i tried them out and they fit just like the lexans and been in there about 5 years now with no problems at all. i know most people ditch the glass ones for wieght reasons but i like them better due to they dont spiderweb and look like crap over time like the lexans do. also like already mentioned there were some that had the hook or latch design in the earlier models.
Old Jan 30, 2009 | 04:25 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Thanks for the replies. My pc is in getting fixed hence the delay in posting a response.
The car the lexan tops came off was a late model firebird with the updated nose (91-92) and from what I can remember the pins were the same size as the ones from my 87 IROC. Was it the diameter of the pins that they changed?
Also, what are the C&C tops? Were these some sort of aftermarket conversion for the tops to be a different size from the ones GM fitted?
Thanks,
Robert
Old Jan 30, 2009 | 05:00 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
C&C stands for Cars and Concepts. They made aftermarket T-Top systems for hardtop cars. They are the most common of the aftermarket 3rd-gen T-top conversions. The entire roof section was cut out between the side windows and the C&C T-top framework installed.
Old Jan 30, 2009 | 05:32 PM
1brd2brd3brd4's Avatar
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
They could be different. I bought a set from a junk yard out of a 92-92 and they were ever-so-slightly bigger, longer front to rear that is.
Old Jan 30, 2009 | 07:09 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Did they fit anyway or were they useless?
Old Jan 30, 2009 | 07:15 PM
They dont fit my 88 T/A
Old Feb 3, 2009 | 11:37 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I've seen T tops where there was a metal strip that went around the T tops.
Mine do not have them on my Trans Am.
So I have seen a couple different styles.
Old Feb 3, 2009 | 03:34 PM
Dens71TA's Avatar
'82-early '85 T-Tops have a black plastic edging that goes around the glass sides of the T-Top.
Old Aug 6, 2010 | 07:52 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Bringing this one back.
Does anyone know what the two different lengths of T-Top are?
Old Aug 6, 2010 | 10:21 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Don't know the lengths, sorry.
But on the pins - the later Lexan tops with the larger pins actually had the same size metal pin inside a slightly larger plastic sleeve - the whole assembly moved outward if you had the top out of the car, but in the car the plastic part butted up against the conical shaped hole and stopped there, while the metal pin continued into the hole to latch.
The Lexan tops usually get replaced by folks with glass tops, because the Lexan gets spider cracks all through the top from years of UV abuse (sunlight), so when looking up through them you see all these crackles in the tops. The glass is heavier, and thus those looking for weight reduction will sometimes swap for the Lexan, the rest of us are swapping for the better looking glass.
Unless the old latch style or the C&C, the tops should be interchangeable. I have replaced my 1992 Camaro Lexan tops with glass tops from a 1986 'Bird with no issues.
Old Aug 6, 2010 | 12:29 PM
Psycho139's Avatar
Car: 1985 Iroc
1982-1992 Camaro/Firebird T-Top Identification Guide
There are only two types of T-Tops for '82-'92 Models. The easiest way to quickly identify which type you have is to measure the t-top glass length where the glass fits under the center t-bar:
Factory Installed T-Tops (Fisher) = 30 1/4"
Aftermarket Installed T-Tops (Cars & Concepts) = 28"
For more info on sizes and parts check out this site.
http://www.sunroofdoctor.com/
Hope this answers your question.
Old Aug 6, 2010 | 01:27 PM
92FBirdVert's Avatar
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
I had 1992 firebird with ttops and my brother had a 1984 camaro with ttops and they would not interchange
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
jbd1969
Aug 17, 2015 07:06 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
