Body work tips
Old Jan 26, 2009 | 04:36 PM
paveuk's Avatar
Body work tips
I did some body work and surprising it turned out pretty good but i need some advice. I stripped body down to bare metal and used rage extreme for filler then rage easy sand for a skim coat. I cleaned oil off with acetone then used por metal ready to etch the metal. I primed with Utech 2K primer. Ok now I see a few small spots I need to fix but my question is can I scuf primer and fix with the easy sand or do I have to take primer back down to filler to apply the filler again?
Old Jan 27, 2009 | 11:02 PM
madhatter's Avatar
Re: Body work tips
what did you use for filler. from what i have read, and done on my car was evercoat rage filler, and y2k primer. when i had touch up to do i used bondo as a spot glaze ontop. my other recomendation is put a couple coats of primer on. and use a long board to sand. it is a must if you want the body to be straight.
Old Jan 29, 2009 | 12:20 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: Body work tips
I'm not familiar with the rage easy sand (unless it's evercoat easy sand)or the primer you used but I believe if both products are catalysed and you just need a light skim coat you can put it over the primer. If it's bad enough that you need to start with the rage extreme again sand the primer off and start over.
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
justin57
Aug 20, 2015 07:05 PM
