What caused this damage to underside?
Old Feb 13, 2009 | 04:53 PM
BlueByU's Avatar
Car: 1991 Z28
I don't know the history of this car, but it looks like someone tried to jack the car up in a weak spot and caused the front fender to buckle out. But there are a couple other pretty bad dents that seem kind of strange to me. I don't know what they are or what could have caused them...maybe you do?
Old Feb 13, 2009 | 05:02 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: What caused this damage to underside?
in the last pictures looks like improperly placed jackstands
Old Feb 13, 2009 | 05:24 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Old Feb 13, 2009 | 05:27 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Originally Posted by iroc a 86 berli
I also agree. The other spots look like someone bottomed that car out on a speed bump or something.
Old Feb 18, 2009 | 11:30 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
that car definitely had some jacking problems in its past. The fender is bowed outwards because someone tried lifting it from the pinch weld where the lower fender bolt is and actually broke it off and pushed the bottom mount of the fender upwards. It looks like you'll need to bend that part of the body back and weld on a new mount for the fender. A lot of people just don't know how to use proper lifting points. and our cars are too heavy to get away with pinch weld lifting like you can on some sub-compacts.
All in all, your damage isn't terrible. The only area that I think you need to fix is where the front fender mounts. The rest doesn't look serious enough to cause concern.
Old Feb 18, 2009 | 11:56 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
It's a well-known fact that nobody (not even dealers) knows how to jack or rack an F-Body. My 91 probably has 5 or 6 spots like that. Even my 02 that I bought brand new has bent up fenders because the dealership thought it would be a good idea to jack the car on those instead of my subframe connectors. Word to the wise: don't let ANYONE attempt to raise your car if you're not there showing them how to do it. These people are idiots and just don't understand.
Old Feb 18, 2009 | 12:02 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Couldnt agree more. My former camaro had the bowed out passenger fender because someone wanted to lift it on the bottom of the fender. My new camaro i always have to instruct mechanics to use a floor jack to get the lift arm past my exhaust to the subframe. Its annoying but so far no bent up lower fenders.
Old Feb 18, 2009 | 01:18 PM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
jacked in the wrong place!
Old Feb 18, 2009 | 02:15 PM
91blue_phoenix's Avatar
Car: 2000 Ford Focus
Engine: 2.0L CVH/SPI I-4
Transmission: IB5
Axle/Gears: stock
Bad jacking/ jack stand placement, and it looks like it ate a speed bump or railroad tracks a little faster than it should have.
Old Feb 18, 2009 | 02:38 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
yeah, that can get you in some serious trouble! hehe
Old Feb 18, 2009 | 03:47 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
LOL funny
Old Feb 23, 2009 | 09:04 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
these cars are hard to jack up.......i put rectangular subframe connectors under my 87....these are bolted to the roll cage.......now i have a decent way to jack the car up without all the "noise"
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
