Rattle can spray paint! Get ready to shoot me
Old Feb 17, 2009 | 04:10 AM
deoverton's Avatar
Car: 1992 Camaro RS
I KNOW THIS IS NOT THE BEST IDEA AND I CAN NOT AFFORD PAINT FOR ABOUT 2 YEARS AND I HAVE TRYED SEARCHING FOR OTHER POST ............BUT
The areas of the car that are already primered are starting to get rust on them I would really like to have a single color instead of waiting 2 years.
I came across this guys car and do it yourself guide and I don't know but with my budget it might be worth a shot
http://www.nicoclub.com/articles.php?id=197237
What do yall think?
Let the badmouthing start haha
Last edited by deoverton; Feb 17, 2009 at 04:14 AM. Reason: hit post button by acident
Old Feb 17, 2009 | 04:27 AM
carlos206's Avatar
Car: 1991 Chevrolet Camaro RS.
Engine: V6
Transmission: Automatic
Axle/Gears: RS.
Re: Rattle can spray paint! Get ready to shoot me
i would do it if i didnt have the money to get a paint job specially if i knew that i would have to wait 2 years. and to tell you the truth flat black is in style. lol
but no on a real note that guys car didnt look bad at all to me when it was done. i say go for it man.!!
good luck (oh and one tip be patient when spaying the car)
Old Feb 17, 2009 | 05:06 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
maybe you will get inspired to finish the whole car after you rattle can it
a buddy of mine rattles and then buffs
looks ok
Old Feb 17, 2009 | 07:50 AM
Mathius's Avatar
What do yall think?
Rattle can is such a PITA.
Do you have a compressor? If you do, you can get a cheap paint gun at Harbor Freight for $20 or less and try this stuff:
Places like autozone carry it, its $20/quart. You can get primer and clear coat and it's a legitimate laquer paint job. The stuff is prethinned and ready to shoot, just stir, strain, and pour. There is about 13 colors available and you can even get a metal flake clear.
You can even mix two colors together to get your own color.
Here are the original colors, they have since added more, like the metal flake I mentioned:
They recommend:
4qts. - Compact
5qts. - Mid-Size
6 qts. - Full Size
So you're looking at roughly.... $160-$200 for paint.
Out of your budget? Then I would still recommend this method before rattle can: http://board.moparts.org/ubbthreads/...0&fpart=1&vc=1
Hot Rod magazine even followed up on this process and it actually works. In fact I think if you skip to the back of the thread, they even found a way to minimize the number of coats by switching to a different type of paint.
I think it costs on average $20 for paint to do a job like that. The downside is the incredible amount of sanding you have to do.
Mathius
Old Feb 17, 2009 | 10:30 AM
userchemical's Avatar
Car: 1984 Camaro Z28
Axle/Gears: 4th gen auburn 3.42 disc
What do yall think?
or you could do this, will cost about the same...and turn out 100% better.
http://www.rickwrench.com/index79mas...llarpaint.html
Old Feb 17, 2009 | 11:54 AM
Mathius's Avatar
Ths is the same thing I posted above from the mopar forum except the mopar forum is where this was allegedly first reported and where the Hot Rod article originated. There is 100X more information on the forums and you can actually talk to people who did it.
I'm suggesting he either try that or the dupli color lacquer. Not because I'm a purist, but because rattle can just sucks. There's such a small fan radius that it would take forever to paint an entire car and something like 30 cans of spray paint for decent coverage. If I had to spray 30 cans of spray paint on any surface eventually my patience would wear thin and I'd have runs or worse, not to mention my wrists would be tired from shaking all those cans.
Mathius
Old Feb 17, 2009 | 12:37 PM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
30 cans? I used 14 or 15 once I haD ALL the body work done on my car. throw down one coat then give it a light scuff with a scoth brite then another and again with the scoth brite and it comes out rather smooth
Old Feb 17, 2009 | 01:17 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Mathius
damn, beat me to it! i thought about doing that myself, but thats to much time that i dont have.
Old Feb 17, 2009 | 01:25 PM
deoverton's Avatar
Car: 1992 Camaro RS
I have looked in to the roll paint time and time again but the time factor of having to do so many coats then do that TON of sanding.
I just can't take this whole regular color/primer,fading color and clear coat fly off down the road.
But like on that link that I have to the spray job, For all the after shots I mean it looks pretty good and even if it looks bad right up close that wouldn't bother me. I'll take something that looks as decent as that does before I would enjoy driving down the road with my current paint scheme
Old Feb 17, 2009 | 01:28 PM
my 83 z28 was flat black, slammed with limo tint. i say go for it. flat black is tough looking.
Old Feb 17, 2009 | 01:35 PM
deoverton's Avatar
Car: 1992 Camaro RS
Does anyone have any pictures of their rattle can spray jobs or maybe some advice on what and what not to do about it?
I already have one of those trigger deals that goes on top of the can with a handle so that should reduce on the fatigue.
Old Feb 17, 2009 | 01:39 PM
look at stephen 87 iroc, he is a mod, his car was flat black, it has flames now, but i think he has pics before the flames.
Old Feb 17, 2009 | 01:49 PM
deoverton's Avatar
Car: 1992 Camaro RS
YES stephen 87 iroc has the exact think I am looking for. Thank you iroc a 86 berli. I figure if I can get my car to look atleast something like that it has got to be better than what I got.
Old Feb 17, 2009 | 02:10 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
As for what to or not to do....
1. Use decent paint. Not that 99cent crap.
2. Make sure you prep the surface decent, and clean with good prepcleaner. Use finer sandpaper then normal, rattle paint doesnt hide the scratches/flaws as well.
3. Tape the areas you dont want painted off just as good as you normally would. Or even remove parts. (to paint or not paint)
4. Make sure you clear it, and dont try to fade the clear like you do paint. You gotta stop the clear on an good edge(body panel, trim, etc).
5. Do long even speed swipes. Not little short 2-3" jots.
The stripes on my car are rattle can, but the red is good paint. Its held up 1.5 years, so it should last an easy 2-3. Alot of spots on my gfx(mainly the nose) is all rattle paint because it keeps getting scuffed up.
Old Feb 17, 2009 | 02:27 PM
no prob dude.
dale, i donno if he is useing clear coat. thought he is going for a flat finish.
Old Feb 17, 2009 | 02:33 PM
deoverton's Avatar
Car: 1992 Camaro RS
Yeah I would kinda like to have the flat black look. Oh and if all goes well with the paint turning out decent I may go back and try to find a teal spray paint that is something like what my car has now and do some stripes down the car to kinda go with my emblems. I am going to post this on the photoshop request and see if someone can make a rough idea of what it would look like.
Old Feb 17, 2009 | 02:58 PM
DanTeix's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI
I just did this, this weekend also cannot afford paint for a bit so Flat spray bomb doesnt look too bad excuse the dirty as rims havent got to them yet.
also Make sure your doing it in a wind free enviroment or you will waste alot of paint. Masking is very important. The Hood I would take off the car and do it seperatly as its hard to get the paint to go on the right way it will be thick in spots and light in others. I would definetly have help because it is tiresome. No ninjas who dont know how to spray though man or youll want to stomp their faces.
Dan
Old Feb 17, 2009 | 03:15 PM
deoverton's Avatar
Car: 1992 Camaro RS
DanTeix how much matierials did it take you to get the job done, and what all sanding and grit did you do. I was just going to take that website I was using as a refence and add aout 5 cans to the primer and paint but I would love to know some of the figures on it for an F body.
Looks great BTW
Old Feb 17, 2009 | 03:26 PM
DanTeix's Avatar
Engine: 305 TBI
If I remeber right there are about 15 cans of flat black sitting in my back yard empty I plan on applying 10 more I had to stop because of rain. As for primer is does not have to be perfect it just has to give the paint somehting to stick to. I used 220 grit under the primer and 400 over the primer I have not sanded the the Flat black yet seeing as it started raining but I plan on 1500 to smooth it out nicley. A word of advice is take your time and you will get a good paint job out of a can. Sometimes others just dont understand when you cannot afford something so they bad mouth. Could even look better then maaco who knows.
Plus flat black does look mean as hell. Good Luck
Dan
Old Feb 17, 2009 | 05:16 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
dont rattle can it, waste of your money and time, prep it mask it and get a cheap gun, rent a compressor if you have to , and get SEM trim black from your local paint supplier and tell him your sprayin it out of a gun he will know what to get you, prep the car and wipe it down 2 times with prepsol, which is a wax and grease remover, then set up your stuff and spray out a test pannel so you can get used to spraying it, then start on the car, light coat for the first, then go pretty nice with the second and third, the car will look amaizing and the trim black is pretty tough, considering its what you see on most cars around window frames that are black and whatnot, i did this to two tone a subaru, it looks sweet and lasts, so please try to do this then rattle can, you will thank me later.
alex.
Old Feb 17, 2009 | 08:44 PM
Mathius's Avatar
Yeah, I had one of those trigger things too. Unfortunately they're about as durable as a toothpick.
Mathius
Old Feb 17, 2009 | 08:47 PM
Mathius's Avatar
I took a guess. I wouldn't rattle can my car for any reason. Again, not because I'm a purist, but because I wouldn't be able to stand the aggrevation of that small little fan radius.
And Dan already posted that he planned on using 30, used 14 and ran out of good weather, so I guess I wasn't that far off.
Mathius
Old Feb 17, 2009 | 09:33 PM
DanTeix's Avatar
Engine: 305 TBI
Mathius
No you were not I may end up using more to get all the light areas out the more u use the more area will cover completly if you use only 15 cans it will look like **** guaranteed. Remember I am taking my time and trying to make it look as good as I can and there is no way it can be done in 15 cans good guesstimate Mathius.
Dan
Old Feb 17, 2009 | 10:09 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
https://www.thirdgen.org/forums/auto...paint-job.html
Cheaper, easier, & better than rattle can.
Old Feb 17, 2009 | 10:40 PM
deoverton's Avatar
Car: 1992 Camaro RS
haha ok you've got me hooked. How hard was it to get into the little creases and all? I am just really worried about having everything run on me. What kind of maintenance does this paint require and do you have some recent pictures of it to see how it looks after a while?
Thanks alot too this might be this weekend project
Old Feb 17, 2009 | 10:46 PM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Rattle can flat black, crappy paint from walmart not even the good stuff, the 98c a can stuff is what I used. No clear coat, lots of sanding before hand some bondo/primer in spots. Another coat and some wet sanding it would have looked GREAT.
Attached Thumbnails Rattle can spray paint! Get ready to shoot me-l_543a7602b8ccdc7aafa2bdea3ee1c11e.jpg   Rattle can spray paint! Get ready to shoot me-l_85519410b883c52d631868cb21bb4c10.jpg   Rattle can spray paint! Get ready to shoot me-l_b4494f8e82cf44e6b39eef1f75c1f680.jpg
Old Feb 17, 2009 | 10:48 PM
jersyboyy's Avatar
Car: 85 Camaro
And another
Tape/cover EVERYTHING up that you dont want paint on.
Sand ALOT,then do a light coat of primer, Sand AGAIN.
Take your time spray the car from like 10-12 inches away with side to side strokes. And dont do it outside like I did cuz well it sucks.
Good luck
Attached Thumbnails Rattle can spray paint! Get ready to shoot me-l_acc362f88e49cac93a4f194d9a727389.jpg
Old Feb 17, 2009 | 11:06 PM
jersyboyy's Avatar
Car: 85 Camaro
after reading FYRCHKN's thread im totally going his route with my next attempt at paint.(got doors and ground effects and different fenders from different cars after my spray paint job)
Old Feb 17, 2009 | 11:09 PM
DanTeix's Avatar
Engine: 305 TBI
Originally Posted by jersyboyy
And another
Good luck
If you can get inside get inside also recommend doing as many of the parts of the car as you can.
Dan
Old Feb 17, 2009 | 11:24 PM
deoverton's Avatar
Car: 1992 Camaro RS
I just got to find a cheap wagner power painter now, I looked on the lowes website but didn't see any for $20. The cheapest I could find was like $60. I have one of those big Craftsman 7 or 10 inch buffer/polishers so I am set for that. I may have to hand sand everything so I will be calling around to see if anyone has a sander I can use lol. So I just need to get those things and go pick up the paint and sand paper. But its not suppose to get over 50 here any in the next few weeks so it looks like its going to be put off for a while atleast. I guess that will just have to get me more time to get ready for it and get supplies.
Old Feb 18, 2009 | 12:54 AM
deoverton's Avatar
Car: 1992 Camaro RS
This is a VERY ROUGH idea of what I would like to have but I am not set in stone on the colors yet. The only reason I thought about this color scheme would be good coverage paint and I could reuse my emblems to match up with the stripes. Plus I have never seen teal stripes. Does it look good to yall? I don't know I kinda dig it as being different.
Attached Thumbnails Rattle can spray paint! Get ready to shoot me-fdsafa.jpg
Old Feb 18, 2009 | 04:51 AM
bejitto101's Avatar
Car: '89 Firebird
Engine: v6
The alternative to Rustoleum if you don't want to have to do as many coats with the roller method is called Intelux Brightside. It provides better UV protection, more scratch resistant and is glossier than the standard Rustoleum Gloss.
You can find colors and info here.
Old Feb 18, 2009 | 09:37 AM
DanTeix's Avatar
Engine: 305 TBI
Its definetly Different than the classic reds and whites. Do you think you would get sick of the teal after a while though? Also if your thinking of doing the wagoner Idea, i would definitely rattle can the stripes. Is that flat black?
Dan
Old Feb 20, 2009 | 05:32 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
what is your budget, im in rock hill maybe we can work something our for a paint job... real paint is not that expensive its the know how if how to use it all...... and once you go spray bomb on your car it double the prep costs cause the crap has to be removed 100% before more real paint can be put on it....
let me know
jeff
Old Feb 20, 2009 | 06:11 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
did that to my old RS didnt come out to bad I had to go to like 20 differnt stores to get enough spray cans though cause for some reason all the stores only carried one or 2 cans of the flat black
Old Feb 20, 2009 | 08:38 PM
bsporty's Avatar
Car: 85 Z28
Transmission: 5 speed
Have you checked out Summit?They have a urethane paint line!You can paint your car for about $300.According to my catalog...primer is $40 p/gal.Base is $80p/gal, activator(for clear and base) is $20 a qt.Clear coat is $60 p/gal, and reducer for $10 a qt.
Old Feb 20, 2009 | 08:39 PM
bsporty's Avatar
Car: 85 Z28
I agree with JeffW!
Old Feb 21, 2009 | 07:23 AM
jamon8's Avatar
Engine: 350 tpi
I use implement paint alot
you can wet sand it later and put some clear on it
Old Feb 21, 2009 | 10:56 PM
FYRCHKN's Avatar
Engine: LT-1
This guy knows what he's talking about. His car turned out beautiful.
I recently did a complete color change on my car to white and I used implement paint from Tractor Supply...gloss white, $30/gallon + $13 for the hardener. 3 coats used maybe half of a gallon. I haven't wet sanded or buffed yet, but the car looks pretty damn good and the paint is very, very durable.
Old Feb 21, 2009 | 11:06 PM
deoverton's Avatar
Car: 1992 Camaro RS
Well its looking as if I aint going to be able to do anything... Wachovia just hit me with a B.S. non suffecient funds charge that went in and messed up about 8 things I paid for just because my check didnt "actually" prosses untill a few days later, even though it always has. So needless to say I ended up paying around 200 dollars to get my account back into the good. HAHA so does anyone have any ideas to do paint even cheaper now?
Old Feb 22, 2009 | 12:11 AM
yea, i would start with a new bank, then worry about paint. perhaps macco
Old Feb 22, 2009 | 07:24 PM
  #42
Mathius's Avatar
I just watched "Trucks" this weekend, and they were talking about how they painted their Jeep Grand Cherokee. The paint came out awesome and they used actual PPG products. I didn't catch what paint line they used, but they said the paint itself cost less than $75 and they had enough left over for touch ups.
You could try looking at powerblock t.v.'s web page. I intend to look into it myself one of these days. Sounds awesome.
Mathius
Old Feb 23, 2009 | 10:19 AM
  #43
pretty good site, u can watch a couple of episodes of each show too. take that cable company!
Old Feb 23, 2009 | 05:30 PM
  #44
fryer1979's Avatar
Car: '79 Camaro; '84 Z28
Engine: 350; none
Transmission: TH-350, 2500 stall; none
Axle/Gears: posi, 3.08; disc, 3.23
If done properly and carefully a rattle can job can turn out pretty good looking. There is no shame in painting your car that way. In fact as you have already seen, leaving a car in primer doesn't seal against rust. I am attaching a photo of my '79 Camaro. It is 100% rattle can. 14 cans of Rustoleum satin black, and 3 cans of Rustoleum satin white for the stripes. A majority of the sheet metal is bare under neath the Rustoleum paint. This car has been painted like this for nearly ten years (one complete redo almost three years ago, I am on a VERY tight budget), and I have never had any issue with rust forming. I always get compliments on the paint, even up close, and almost always receive shock when I tell people it is only off the Wal-Mart shelf spray paint. Good luck with yours!
Old Feb 23, 2009 | 05:57 PM
  #45
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Unless you use a primer/sealer
Old Feb 23, 2009 | 08:14 PM
  #46
fryer1979's Avatar
Engine: 350; none
True.
Old Feb 24, 2009 | 02:07 AM
  #47
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I think this is crazy, but do-able. Someone told me the drifter crowd does roller jobs.
Huge discussion:
Old Feb 24, 2009 | 04:42 AM
  #48
deoverton's Avatar
Car: 1992 Camaro RS
Huge discussion:
I looked in to the roller method quite a few times but its so time consuming with having to wet sand so much. Plus I honestly think I would have more trouble doing it after hearing so many people talking about the roller leaving marks and extreme amounts of orange peel. I know if you did it enough times you would end up getting decent out it but by the time I figured out the right way for me to do it I would have a good enough job to get a regualar paint job.
Old Feb 25, 2009 | 02:51 AM
  #49
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
Wow thats awsome fyrchkn. That color is some what simular to what I wanted on my car any way I will do this in a few weeks. Where is Bastrop? Never heard of it. Coarse then again thousands of towns in Texas I dont know about.
Old Feb 25, 2009 | 08:13 AM
  #50
this thread got me thinking, instead of getting a crap macco job, im gonna do the roller method, or i might just buy a cheap gun and a dryer for the air compressor. altho fryckin's method looks pretty good too. so i went and picked up the paint last night and some spirits.
