? Body Repair ?
Old Feb 23, 2009 | 07:31 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
? Body Repair ?
I have a couple quarter size rust spots in my spare tire well where the jack is as well. It rusted right through and want to repair it. I'm curious on my cheapest option to fix this in the best way? If anyone has done this before could you give me your options and procedure?
thanks in advance,
Timinsk
Old Feb 23, 2009 | 07:34 AM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
Re: ? Body Repair ?
if you have access to a welder can use some sheet metal and tack it from inside .and on the outside you can do body filler to smooth it out..
Old Feb 23, 2009 | 07:49 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: ? Body Repair ?
ok
if you dont have a welder and you want to do it right
todays auto manufactures are using panel bonder to put the cars together
wire wheel the rust out and treat with por 15
make some small patch panels
you have to form them almost perfectly
with a welder you can tack and beat into place
after forming use a bunch of panel bonder
Old Feb 23, 2009 | 08:13 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: ? Body Repair ?
If you have access to a welder, it would be best to cut a patch piece of sheet metal to fit the hole and weld it into the hole. Then grind the weld down, bondo and paint. Just make sure you grind/wire wheel all the rust off and cut out the rotted metal back to good metal so you get a good solid weld. Once you *think* you have gotten all the rust, spray or brush on some type of rust converter or rust neutralizer to make sure it doesn't come back. The problem with rust is that if there is any left behind, it will eventually eat through the repairs. It may take 10 years, but it will reappear.
Old Feb 23, 2009 | 08:20 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: ? Body Repair ?
If you don't have access to a welder, you can "glue" the patch in place, which is what I think jamon8 was getting at. Basically you would follow the above mentioned rust removal steps, then cut a patch piece slightly larger than the hole. I would go about an inch on all sides. Pick up some panel adhesive at the local body shop or body shop supply store. Follow the instructions on the adhesive to glue the patch behind the panel being repaired. Then bondo and paint.
Old Feb 23, 2009 | 12:51 PM
redbird92''s Avatar
Car: 92' firebird
Axle/Gears: 10 bolt POSI 3.73's
Re: ? Body Repair ?
If had needed to do a cheap repair without a welder i would
1- Sand down most of the rust as you can
2- treat rust (I like rustbullet) Menards has some oil base alluminum paint that I like too
3- fiberglass using fiberglass mat
Its not the best way but works
Old Feb 24, 2009 | 04:38 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: ? Body Repair ?
another option if you don't have a welder is to take a piece of sheet metal, my friend used aluminum. Clean out all the rust and pop rivit that piece over the holes. Then use either Duraglass or Bondo fiberglass filler to seal it up on both inside and outside. Spray over the area with some canned rubberized undercoating. It won't be pretty, but it will work. If it's under the car, you won't even see it. Then at some point down the road, you can drill out the rivits and remove the metal, and fix it with new metal and a welder.
Old Feb 24, 2009 | 08:37 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: ? Body Repair ?
I forgot about the pop-rivet method. The other thing you can do with that if it's on a visible panel is to use a ballpeen hammer to dimple the surface where you're going to put the rivets so that the heads are below the surface. Then bondo over the heads and sand and paint. Again, not ideal, but it will work.
Although, if you're going to do any temp repairs, no matter what method, you probably shouldn't bondo over them as you'll have to remove all that bondo to fix it right and that is not an easy thing to do.
Old Feb 24, 2009 | 05:34 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
Re: ? Body Repair ?
I've repaired some rust holes in the floor pans by removing the rust, spraying a rust inhibitor around it, then either use a piece of aluminum and use JB weld then primer/paint OR I've used fiberglass cloth with epoxy resin, primer/paint. Now, these were in areas that arn't seen so I wasn't concerned with appearance. The resin stinks likes crazy and you have to work fast but its really strong and rustproof. Use 4-5 patches of cloth and apply resin between the patches.
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
mrdevontay
Sep 2, 2015 08:04 PM
