camaro body/interior
hey, i have a 1986 chevy camaro z28 and the passenger side floor board is rusted out and i have to replace it. any one know where i can get that piece at a relatively cheap price?? any answers will be appreciated, thanks.
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: camaro body/interior
2 options
spend a few hundred on a replacement passneger floor pan from hawks thirdgen parts or somewhere else
or if its not the whole floor pan and just where the persons feet go then take it to a welding shop and pay a few bucks for a piece of sheet metal and whatever labor is for them to weld it in
goodluck
goodluck
you could try to go to the junkyard and cut it out
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If you go to a junkyard, get more than what you need... It is easier to take away from your new piece than try to add to it.
John
John
Axle/Gears: no idea
i would use the junk yard as a last resort personally
onyl because so much time spent on trying to find a thirdgen at a junk yard thats in decent condition and not rusted out
also taking the time to plasma cut or cut any way how to get the floor pan out
i think it would be easiest and quickest to remove your passenger side seat and carpet and drive it to a weld shop let them cut out the bad metal and patch in new steel
but you have been given 3 options do whatever you want
84z96L31vortec
Aug 20, 2017 12:16 AM
