Rusted floor boards
Old Mar 25, 2009 | 09:05 AM
Fink's Avatar
Car: 1986 camaro irocz, 1995 formula
Engine: 305 tpi
Rusted floor boards
ok so im sure some of you guys have had to deal with rust.
ive actually had my car torn apart for awhile but its been on hold untill now.
i was wonder what is the best way to go about fixing rust hole in the floor boards. should i just pop rivet in some sheet metal? or replace the whole floor board?. obviously the new floor boards will cost me more. any input?
thanks, Adam
Old Mar 25, 2009 | 09:21 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: Rusted floor boards
I am a fan of sheet metal... at some point it's not safe enough though!
If you are rusted just in the low points where water is expected to pool up then sheet metal. If you are rusted across the floors to the point where even your seat brackets are toast then it's better to cut out the floorboards and weld new ones in place.
Old Mar 28, 2009 | 12:30 PM
Fink's Avatar
Engine: 305 tpi
with the amount of rust that is there im pretty sure its just smarter to replace the floor boards. but im having a hard time finding them. where can i buy them from? and do they sell them in sections? or just the whole pan?
becuase the only part that has rust on it is in the front where your feet sit.
Old Mar 28, 2009 | 08:43 PM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
How about some pics?
Old Mar 28, 2009 | 08:50 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I believe year one sells complete floor pans. Don't know of anyone that just sells sections... you might get lucky and be able to cut the piece out you need at the bone yard...
Old Mar 29, 2009 | 04:48 PM
Fink's Avatar
Engine: 305 tpi
i will try
Old Mar 29, 2009 | 09:06 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
http://www.yearone.com/serverfiles/f...archid=1601676
This should be what you are interested in.
LC2 TECH
Oct 13, 2015 11:53 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Linson
Oct 1, 2015 09:50 PM
zman1969
Oct 1, 2015 11:09 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
