spraying base clear
Old Mar 29, 2009 | 09:24 AM
howy03's Avatar
Car: 1985 Pontiac Trans Am
spraying base clear
I started to cut in my drivers side jams fender and door 3 coats of ppg base.I did not get a chance to clear it last night.My question is can i spray the clear today even though it is raining out?My garage is completly dry but the humidity is high today.I will heat the garage to about 65f.will this have any bad effects?
Old Mar 29, 2009 | 10:12 AM
RedHawkLB9's Avatar
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
Re: spraying base clear
Yes...just rescuff it with 1000/1200 sand paper clean it off and spray the clear..let the clear flash between coats...and if you have one put a heat lamp near it(not 2 close tho lol)
Old Mar 29, 2009 | 10:19 AM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
Yeah, you'll be fine. Scuff it and shoot it. Most base coats don't even require a scuff if cleared within 24 hours.
Old Mar 29, 2009 | 12:50 PM
NatesZ/28's Avatar
Car: '00 Regal GS/'87 T.A WS-6
Engine: stock 3800 series II/stock 5L TPI
Transmission: fwd auto/stock 700r4
Axle/Gears: wrong wheel drive/3.23:1 Posi
check your tech sheet, you may not even have to scuff it. Tech sheets for all the major paint companies are usually available in pdf's online. If youre within the recoat window, wipe it down with some prepsall, let that flash real good, and then shoot it. If you have to scuff it with P1000, make sure to wipe it down real good with a tack-rag as well
Old Mar 29, 2009 | 01:53 PM
howy03's Avatar
Thanks for the tips,I just sprayed it and it looks awsome!
Old Mar 29, 2009 | 03:39 PM
NatesZ/28's Avatar
Nice!
Old Mar 29, 2009 | 03:46 PM
howy03's Avatar
makes me want to say scew it and paint the whole car.But I am only cutting things in I have a real good guy spraying and sanding and polishing for $300 with my help.This color looks awsome on a third gen if any one out there has a maroon color and want a nice change.Its of an 08 Tundra salsa red metalic pearl.
cowansauto
Apr 3, 2025 12:51 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
db057
Jan 10, 2020 08:55 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
