T-tops difference
Old Apr 6, 2009 | 08:27 PM
pro69ss's Avatar
Car: 73 Camaro
Engine: 355
Transmission: TH350
Axle/Gears: 3.23 posi
T-tops difference
I got a set of t-tops from a friend and they looked like a matching set, HOWEVER, one side (LH) is "pin-style" and the RH side is a "hook-style".
This is very odd since they are factory tinted and came off same car (supposedly). Can you change out the mechanisms at all? Can you also change locks out?
Old Apr 6, 2009 | 09:55 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: T-tops difference
You can change the brackets they latch into and the trim that goes with it. But who would want 2 different types on the same car.
Old Apr 6, 2009 | 11:49 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
You can also change the hardware over from one top to another. I removed the hook style hardware from the tops I found in a junkyard and sent them to a friend for his lexan tops (which had pins) he uses for racing.
Old Apr 7, 2009 | 07:10 AM
pro69ss's Avatar
Car: 73 Camaro
Engine: 355
Transmission: TH350
Do you know how to swap the hardware out? I looked at them last night and could not figure out how the hardware comes off. Does everything come off as one piece? or in pieces?
Old Apr 7, 2009 | 10:14 AM
Al Hasse's Avatar
It's been a while, but the mechanism comes off in one piece. Of course, the trim all has to come off first, then about eight or ten screws hold the mechanism to the top.
Old Apr 7, 2009 | 06:34 PM
pro69ss's Avatar
Car: 73 Camaro
Engine: 355
Transmission: TH350
piece of cake, once I knew what to look for. Thanks for the tip.
Now I have a spare set.
Bohemian
Aug 15, 2017 05:11 PM
89 formula TPI
Oct 6, 2015 08:40 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
