ANOTHER MILLION DOLLAR QUESTION!!!!!!!
Old Apr 7, 2009 | 01:13 AM
1985IrocZ's Avatar
Car: 1985 Z28
Hi everybody,
Here's the million dollar question. My passenger side door is sagging.....almost 1/2 inch, but not enough to scrape the rocker panel. But, the tricky part is that it's not sagging from the the end of the door that has the door lock, it's sagging from the end that has the hinge. Has anyone seen this before???? Is it possible that my screws screwing the hinge to the body have come loose and simply need tightening and elevating???? Thank you for the help!!!!!!
Jon
Old Apr 7, 2009 | 01:16 AM
Stephen's Avatar
Car: 87 GTA
Re: ANOTHER MILLION DOLLAR QUESTION!!!!!!!
The hinge bushings are wore out. Common problem, $200 for uppers & lowers, both sides.
http://www.top-downsolutions.com
Old Apr 8, 2009 | 03:18 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Only 1/2 inch.... my god your in luck that's a good door!
No just get a hinge rebuild kit and you will be good. I have had a pin break and the door was useless.
Old Apr 8, 2009 | 03:20 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
agree bad hinges/pins
Old Apr 8, 2009 | 03:42 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
yuppo. repair it asap
Old Apr 8, 2009 | 07:58 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
I'd really like to see a picture of this problem.
Old Apr 8, 2009 | 09:56 PM
1985IrocZ's Avatar
Car: 1985 Z28
As far as the picture is concerned, I will try, but can't garantee anything. And as far as the problem is concerned, I have to say that unfortunately I am still confused. EVerybpdy seems to have different opinions....between hinges, pins, bushings. I hope I wont have to buy everything. Working on a budget here.
Old Apr 8, 2009 | 10:00 PM
Car: 86 T/A
Engine: 5.0 TPI
I am a little confused too, thats why I was hoping for a pic.
Old Apr 8, 2009 | 10:23 PM
1985IrocZ's Avatar
Car: 1985 Z28
OK, I WILL TRY TO GET THEM TOMORROW.
Old Apr 9, 2009 | 10:32 PM
1985IrocZ's Avatar
Car: 1985 Z28
here are the pictures taken today. hope that helps
Attached Thumbnails ANOTHER MILLION DOLLAR QUESTION!!!!!!!-camaro-door-002.jpg   ANOTHER MILLION DOLLAR QUESTION!!!!!!!-camaro-door-001.jpg   ANOTHER MILLION DOLLAR QUESTION!!!!!!!-camaro-door-004.jpg
Old Apr 9, 2009 | 10:37 PM
Car: 86 T/A
Engine: 5.0 TPI
When the oil change place put your car up on the hoist they crushed the bottom of your fender. That pushed your fender up. Look how the bodyside moulding doesn't line up. Get down and look under there ... you'll see.
Actually I may be confusing you with another guy who just had his oil changed but the same condition still applies.
Old Apr 9, 2009 | 10:59 PM
jaygod8's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 2.8L V6
After looking at your pics that's what my door had looked like on my last Camaro. I got LUCKY...the door was just misaligned (Not so lucky on this car, I had to replace the pins/bushings). Before you go and buy parts open the door and lift on the back of it (where the lock is). Does the door move up and down? Pay attention to the upper and lower hinges when you do this (it's easier with another person doing the lifting while you watch the hinges). Do the PINS or BUSHINGS move/shift? If Not, you may just have to loosen the bolts connecting it to the body and Re-Align the door. If they do move/shift, you're gonna want to talk to Lon at TDS about the repair kit(s).
Old Apr 9, 2009 | 11:17 PM
1985IrocZ's Avatar
Car: 1985 Z28
here more pics...
Attached Thumbnails ANOTHER MILLION DOLLAR QUESTION!!!!!!!-camaro-door-005.jpg   ANOTHER MILLION DOLLAR QUESTION!!!!!!!-camaro-door-006.jpg   ANOTHER MILLION DOLLAR QUESTION!!!!!!!-camaro-door-008.jpg
Old Apr 9, 2009 | 11:27 PM
1985IrocZ's Avatar
Car: 1985 Z28
wow, Jason, thanks for the info. I will check tomorrow for any movement in the pins. But when you say bushings, what do you mean??? I dont remember seeing them there. It just seems to be a pin going through a hinge, without anything made of rubber there.
Old Apr 9, 2009 | 11:59 PM
jaygod8's Avatar
Engine: 2.8L V6
The Bushing are Copper which is why you don't see any rubber..lol. From the latest pics I can't really tell if your lower hinge has the bushing in the bottom half or not. (When your car was repainted they painted the hinges, pins, and bushings) In the 1st pic you posted at 11:17 you can see the bushing just above the Top Half of the Lower Hinge. Where the pin goes into the Lower Half of the Lower Hinge is where I can't tell if all the bushing is there or not. (you should see a "lip" either on the top or bottom of that hole depending on if the bushing has been replaced and if the person who did replace it did it right. If the bushing is there and was installed correctly you should see the "lip" on top)
Old Apr 10, 2009 | 10:22 AM
Car: 86 T/A
Engine: 5.0 TPI
Take another picture for me. Under the gfx at the point where the fender bolts on at the bottom. I want to know if the flange on your car bent in or out when they jacked it up.
Old Apr 10, 2009 | 10:31 AM
1985IrocZ's Avatar
Car: 1985 Z28
how do you know wether its bent at all???? I'll try to have that done by tomorrow
Old Apr 10, 2009 | 08:07 PM
Car: 86 T/A
Engine: 5.0 TPI
I know because I've been working in a Pontiac Buick and GMC dealer bodyshop since third gens were brand new cars and I've seen your problem before. I do admit there is a slight chance I could be wrong. From your pics it looks like all your pins and bushing need is a little grease. It's a little hard to tell from a pic but they look pretty good.
Hey I'm just a guy trying to help you make your car better and keep you from spending your hard earned money on problems that may not even be there.
Nice color btw. I like that yellow. Do you have a whole car pic? Oh crap there I go asking you for another pic!!!!
Old Apr 10, 2009 | 10:09 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
I would also say its your fender. Look at where I circled on your picture. YOu can see the GFX is off a bit.
Old Apr 11, 2009 | 04:14 PM
1985IrocZ's Avatar
Car: 1985 Z28
Thanx 1piece@atime for the valuable info and the help. But here's a little update. Some people posted that I should lift the door when it's opened to see if there is any play. I've done that....and no play at all. So that tells me that either the door or the fender is not alined properly. As far as the door is concerned, the 3 bolts holding down the hinge to the body....are those adjustable or or straight screw in with no adjustments??????
Thanks GroundRAt for your info as well. But if you are right about the fender having shifter, then where would be the adjustment? I should point out that the fender is perfectly lined up with the front bumper and the hood. Also, considering that gravity goes down, then why would the fender shift upwards? I can see more the door, with its heavy weight and movement, being prone to shift downwards. And I wrong for thinking this????
BTW, 1PIECE@ATIME, here's the whole car picture you requested. Let me know what you think.
Old Apr 11, 2009 | 04:20 PM
1985IrocZ's Avatar
Car: 1985 Z28
here's another picture...
Attached Thumbnails ANOTHER MILLION DOLLAR QUESTION!!!!!!!-camaro-night-013.jpg
Old Apr 11, 2009 | 04:39 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
My first question was going to be how does the hood line up to the fender, but if they are even on top, then your fender should be fine. Yes, the door is adjustable at those 3 bolts. The bolts themselves do not move. The holes for them in the hinge itself are oversized for the bolts to provide the adjustment. They are basically big squares. You will have to loosen all the bolts on both hinges to be able to adjust the door. IIRC, to access the bolts on the bottom hinge, you have to take out the kick panel under the dash. Just loosen the bottom bolts a tiny bit, you don't really want them to move much based on your pics. The top ones you'll want to have 2 pretty loose and 1 slightly loose. That way, once you think you have the door in position, you can tighten that one bolt to hold it in place while you check the alignment. It's best to have a friend there to help you since the doors are so long and heavy. I did mine solo though, so it can be done. You can buy a special tool to help align the door, and I'm sure it helps but its not required.
Old Apr 11, 2009 | 04:47 PM
Car: 86 T/A
Engine: 5.0 TPI
Nice car ... good luck with your problem.
Old Apr 11, 2009 | 05:22 PM
groundrat's Avatar
Car: 91Z28
Look under the car at the fender behind the wheel right in front of the door. This is usually where it gets jacked up improperly. It will force the lower part of the fender up and baloon out the middle. Exactly what you are showing here. I had this problem on both my camaros.
Hawk312
Aug 22, 2017 08:55 PM
Matt86IROC
Sep 7, 2015 06:30 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
Vintageracer
Aug 11, 2015 08:13 PM
