are these the same? bumper cover support.
Old Apr 9, 2009 | 07:25 PM
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
are the camaro and firebird front bumper supports the same? i found a 4 cyl camaro with an aluminum front bumper support, but i have a firebird...so will it work?
Old Apr 9, 2009 | 07:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: are these the same? bumper cover support.
im quite sure it will, but the plastic honeycomb absorber stuff is different
Old Apr 9, 2009 | 08:20 PM
Engine: 2002 Ls1
Transmission: t-56
anyone else?
Old Apr 9, 2009 | 08:49 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Any way you could check while your at the yard? Compare the two.
I have an aluminum one I took off a 84Z (I think) at the JY. And it angles back at the corners. All I know for sure, is that I'll have to remove the honeycomb and put the honeycomb off my 91 Camaro on it.
I think you can still use it even if it is slightly different if you don't use the honeycomb. I know a few people who removed the honeycomb for "weight savings".
Old Apr 10, 2009 | 04:01 AM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
I have the same thing! I bought an aluminum Z28 front support off Ebay a couple of years ago and having replaced my rusted out rear support with one from a junker just recently I thought 'WTF, let's clean up that front one in storage and swap it out too!'
After spending a slow weekend stripping, sanding down and painting the aluminum support, I find that it is a DIFFERENT SHAPE to the one on my 91 Camaro!!!!!!
Anyone have this problem before? Can I remove the honeycomb off my old support, rivet it to the aluminum one and make it fit? Or have I just wasted my money and my time...?
Old Apr 10, 2009 | 09:28 AM
krisb410's Avatar
You just have to swap your honeycomb off your car onto the aluminum bumper, so I've heard/read. Stevo, I've actually seen his car, (and a few other members) put one on his (their) 92 Camaro (or other years), but he left the honeycomb off (don't remember, but I'm pretty sure the others just swapped the honeycombs). I honestly don't see how it wouldn't work with the honeycomb swaped. Should be pretty straight foward swap.
Old Apr 10, 2009 | 10:15 AM
Engine: 2002 Ls1
Transmission: t-56
anyone know for sure? so i dont tear into to it and end up making it a week long project?
Old Apr 10, 2009 | 10:21 AM
Stephen's Avatar
Car: 87 GTA
I know FOR SURE.....IT WON'T FIT.
I had to replace my nose 2 weeks ago & have a 84 Camaro aluminum support.
Figured while I'm in there, I'd swap them out.
Not only are they shaped a little different, but even the attaching "feet" don't come even close to lining up!
I had always just heard the Firebird ones were just a bit narrower. Figured I'd cut, trim & be good to go. Nope. Wasn't gonna fit without a LOT of surgery. I do mean SURGERY!
If you can get it cheap, buy & resell it. Pretty easy to sell to the Camaro guys for a weight savings for them.
Old Apr 10, 2009 | 10:32 AM
Engine: 2002 Ls1
Transmission: t-56
whats it worth?
Old Apr 10, 2009 | 11:24 AM
krisb410's Avatar
I guess as long as your interchanging camaro/camaro or bird/bird you can do it then.
I paid $40 for my 84 Z28 Aluminum bumper.
Old Apr 10, 2009 | 06:37 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
I've never noticed any difference in the bumpers,just the impact absorbers whether its bird or camaro?
Maybe Stephen or someone else thats absolutely sure can supply us with some pics of the differences?
Old Apr 10, 2009 | 06:41 PM
Stephen's Avatar
Car: 87 GTA
I set the aluminum Camaro one on top of the GTA one, but didn't take a pic.
I'm SURE, but no pics. Others are welcome to buy one & spend their day to find out & take pics for us!
I have a pic of my GTA with the nose off, but not with the Camaro piece set on top to compare.
Old Apr 10, 2009 | 06:58 PM
yeah man,that bird one looks a little taller now that I see a pic for reminders.
And dude!! What the hell did you do to your car to require removing the bumper and needing to replace the fenders??
yeah man,that bird one does look a bit taller than a camaro now that I see a pic of it.
By the way Stephen,what did you do to your car to require front bumper removal and fender replacement?
Old Apr 10, 2009 | 07:07 PM
Stephen's Avatar
Car: 87 GTA
Old man clipped the corner of my bumper, ripping that corner off & crinkling that fender backwards. I still need both fenders (bambi took the other one out) but the car is perfectly driveable & the fender damage to the other side isn't bad now, just some wrinkling.
Accident Pics
I'm actually considering putting on standard TA fenders on, with the vents. I like the vents, even though GTAs never had them. I build my cars to suit ME, not the masses, nor strive for perfection
Anybody wanna donate some fenders?
Old Apr 10, 2009 | 07:31 PM
Accident Pics
eesh!!! Sorry to hear that man.I don't have any fenders but I do still have the nose.
Looks like you need one to me anyway.
Remember,this is a donation but,the bus ride ticket has to come out of your pocket.
Anyway,the op still need any opinions or advice?
I don't want to get off topic here.
Old Apr 11, 2009 | 07:45 PM
Engine: 2002 Ls1
Transmission: t-56
hey, if anyone has one off a 4cy firebird want to trade for one off a 4 cy camaro?
Old Apr 11, 2009 | 07:49 PM
Stephen's Avatar
Car: 87 GTA
They aren't limited to just 4-cyl cars. Mine came of a Z28.
They were limited to 82-84.
Old Apr 11, 2009 | 08:03 PM
Engine: 2002 Ls1
Transmission: t-56
maybe my 84 has one already lol
Old Apr 21, 2009 | 11:40 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
you want to get rid of that bumper support stephen?
Old Apr 22, 2009 | 12:06 AM
Stephen's Avatar
Car: 87 GTA
PM replied to.....
Old Apr 23, 2009 | 02:13 AM
Engine: 2002 Ls1
Transmission: t-56
are you selling it?
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
jessejames82
Oct 16, 2015 10:11 PM
xbazzarex
Exterior Parts for Sale
16
Oct 6, 2015 08:42 PM
codeysabatini
Sep 24, 2015 05:40 PM
SG91camaro
Sep 5, 2015 10:27 PM
