Hood Pin Install Trick
Old Apr 15, 2009 | 02:15 PM
1Aauto's Avatar
Former Sponsor
Here's a little trick for you guys that want to install hood pins.
Install the pins onto the frame section of the car as the directions state.Put some chaulk or, I used wheel bearing grease on the top of the two prongs sticking up.Gently lower the hood,so that it sits on top of the pins.This will leave a mark on the underside of the hood,letting you know the exact location to drill the two holes for the pins. To drill the actual holes, bought a cone shaped drill from Home Depot to drill through the fiberglass hood.
Hope this helps
Old Apr 15, 2009 | 02:41 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Re: Hood Pin Install Trick
indeed...
Old Apr 15, 2009 | 02:56 PM
TireSmokin''s Avatar
The better halfs lipstick works too.
Old Feb 7, 2010 | 04:58 PM
masterp_17us's Avatar
Thanks for the lipstick Idea I'm gonna try it now! Much better then digging through my poor garage looking for grease!
Old Feb 10, 2010 | 12:59 AM
Vulgar's Avatar
Car: 82&86 Camaro
Engine: 540BBC/383Stroker Tunnel Rammed
Transmission: TH400/TH350
Axle/Gears: 4.56/3.73
You have lipslick readily available, but not grease? You'll have to excuse me if i find this a little odd.
Old Feb 10, 2010 | 01:36 PM
Klewis89RS's Avatar
Car: 86 IROC, 90 F-250
Engine: LB9, 460
Transmission: 700R4, C6
Peanut butter works well also, creamy not chunky.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
bryan623
Aug 10, 2015 11:33 AM
