'87 camaro t-tops
Old Apr 21, 2009 | 05:06 PM
myown_mortality's Avatar
Car: 1987 Camaro IROC-Z
Engine: 5.7L 350 TPI
'87 camaro t-tops
hey there, i'm new.
i've got an '87 IROC, and i recently purchased a bunch of parts off a guy who used to own an '85 IROC. one of the things i got (that i didn't particularly NEED... but i wanted!) was new t-top glass, with plastic/rubber around the edges of the glass and black edges that hang over the side. the ones i have now don't have anything around the edges and the overhang is grey.
i tried putting the new ones on my car today, and they didn't fit. i couldn't lock them in.
i didn't think they changed much of the body styling from '85 to '87... so is this just me?? somebody help!
here's a picture of my baby. she needs some lovin', so be gentle.
Old Apr 21, 2009 | 05:16 PM
madhatter's Avatar
Re: '87 camaro t-tops
Originally Posted by myown_mortality
hey there, i'm new.
well you have to first look at the pin size. there will be pins that come out of the sides of the tops that lock them into retainers, there are two different pin sizes, small, and big. you may have a problem with that. secondly you may just have to adjust the retainers that the pins fit into. nothing body wise changed
Old Apr 21, 2009 | 05:42 PM
good call! the pins on mine are a tiny bit wider and longer than the new ones i got. is there anything i can do about that?
the new ones are so much nicer!!
Old Apr 22, 2009 | 01:51 AM
madhatter's Avatar
take them apart and switch the locking mechanism and the pins. it is only like four screws, its not hard to do. there is a post on how to do it somewhere on here
Old Apr 22, 2009 | 08:40 AM
i didn't know you could do that - with enough time, i'll figure it out! thanks.
Old Apr 22, 2009 | 09:51 AM
Camman9167's Avatar
Car: 1991 Camaro RS
Engine: 305 Small Block
Axle/Gears: Factory
same thing happened to me just crank on them till the leaver on the tops closes and they will work themselves out. mine had a wide clip the older camaro clips are skinnier bu they still work.
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
t-top89
Aug 21, 2015 09:52 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
