Front License Plate (Ca.)
Old May 9, 2009 | 08:28 PM
Chuck Moehring's Avatar
Car: 84 Firebird SE
I'm in Calif. and have been recently asked to display my front plate. Is there a factory display frame? It's a compound angle and easy to make ugly. Anyone have pictures of an 84 Firebird with one? Would appreciate any help here.
Old May 9, 2009 | 10:01 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Front License Plate (Ca.)
They just don't look right with the tag on front, I'm glad GA doesn't have front tags.
There is a dealer option (it may be factory) peice that mounts there
here is a google search with some with tags. http://images.google.com/images?sour...N&hl=en&tab=wi
Old May 9, 2009 | 10:35 PM
Car: 84 Firebird SE
Thanks Aviator857,
You're right, they just don't look right with it. I took a look at your car. Looks great. Mine is an 84 se and the same color (factory water base).
You mentioned that your seats weren't stock. They look good. Where did they come from and do you think they would fit in an 84?
Thanks for the link and thanks again for your help,
Chuck.
Old May 9, 2009 | 10:43 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
The seats are out of a 97 camaro, the center console is out of a 2000 Trans-am. The seats fit easily from 82-2003 The rear bench back is slightly narrower on the 4th gen cars but look fine. Splice in the controls if its electric adjust, otherwise its a direct bolt in.
If I had to mount a front plate I would fab something up that mounts to underside of the bumper so I didn't have to drill holes in my bumper cover. I guess putting it in the window isn't an option in CA.
Old May 9, 2009 | 10:49 PM
marko3rdgen's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
im having the same problem you are i took off my plate from the front didnt like the way it looks and now i have to put it back...got a fix it ticket!!! i have until this thursday to find the plate bracket on my camaro
Old May 9, 2009 | 11:00 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
In Australia we have to have a front plate also. I mounted mine underneath and to prevent braking off or scraping badly used a piano hinge with a piece of foam behind that to bring it back to the normal position.
Old May 9, 2009 | 11:01 PM
Stephen's Avatar
Car: 87 GTA
A woulda turned up my hidden license plate bracket, which uses 2 of the already existing bolts underneath.
https://www.thirdgen.org/forums/fabr...nse-plate.html
The factory license plate holder gets screws straight into the bumper cover & messes up the paint.
When I replaced my front fascia, I tossed my plate in the windshield, so I'm not even using the hidden brackets I made anymore.
Old May 9, 2009 | 11:12 PM
87_TA_GTA's Avatar
Car: 87 T/A GTA
Engine: 5.7L TPI
Axle/Gears: 3.27:1
man i wish i saw that before i bought mine, would of saved some time. this is what i bought: http://www.autoattire.com/stngofrho.html
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
