Drivers side t top weatherstrip
Old May 21, 2009 | 01:55 PM
87_Injected's Avatar
Car: 2010 2LT RS
I have an 87 IROC. I also have a little leak on the drivers side t top. I noticed the weatherstrip that sits on top of the door glass does not run in full length to touch the rear portion of the car. This is where my leak is coming from. Here is a pic..
As for the front of the car.. it seems to be ok but could be better. I suppose this strip has shrunk? Rubber still seems to be soft. What is this strip called and where can I find it? I don't want to buy the whole kit.
Old May 21, 2009 | 03:10 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Drivers side t top weatherstrip
The t-top can be adjusted down the mounts on the car where the pins from the t-top go in are adjustable. This will help tighten up the seal a little better.
The rear it looks like the door seal has pulled down some you may want to reglue it.
Potroleum jelly will make the rubber expand also, not a forever fix as it will degrade the rubber also.
I've had luck using weather striping repair glue to add bulk to the seals in a few spots. I don't have leaks except if you hit it with a pressure washer at the car wash.
Also you can adjust how high the window will go up and that will push the seals together better.
I don't know where you can get the one seal, but I would replace all the seals on the one side at the minimum.
Old May 21, 2009 | 03:38 PM
nick87iroc's Avatar
Car: 1985 Monte Carlo SS
Engine: 5.0 305 H.O.
Transmission: 200-R4
Axle/Gears: 3.73 Posi
its called a T-Top Weather Strip...You can get them at Advance Auto...the only reason i know is cuz ive bought some for a buddy thru there, but its about $125, you also can only get them in the set brand new
Old May 21, 2009 | 03:51 PM
Car: 2010 2LT RS
Well again I don't want to buy the whole kit because the weatherstrip on the whole car is brand new. Previous owner restored it. I will see if the rear portion on the door needs to be reglued. I recall seeing that it looked to be in place, maybe its just warped a little.
Old May 21, 2009 | 05:36 PM
odecca's Avatar
Car: 89 RS
Engine: 305... for now.
if they are new (and they look new in the pics) I would try what Aviator857 said. It has been a while since I replaced a set on my first Z but as I remember it the door piece sat much tighter than that.
Old May 21, 2009 | 06:19 PM
Car: 2010 2LT RS
The passenger side sits pretty good. I'm hoping to get the drivers side fixed before I move to South Florida next month. Especially with hurricane weather etc.. However it will be sitting indoors protected, just don't want to get caught in a sudden downpour.
Old May 29, 2009 | 09:20 AM
1Aauto's Avatar
Former Sponsor
We carry both weatherstrip kits and also the seals individually.We do carry those outer T-Top weatherstrip pieces if you need them.
Here's a link to our Camaro Weatherstrip Section
Old May 29, 2009 | 10:29 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The problem you have is not knowing which weatherstripping piece was replaced, the body or the top. if you do know, then you need to fix the other piece.
The way I see it, the body weatherstripping was replaced with an aftermarket set that doesn't fit correctly. Now you need to find the ttop weatherstripping from the same company or buy a new body set. I bought GM and mine seal tight like they did when the car was new. Aftermarket parts aren't always the best fit!!
Old May 29, 2009 | 10:35 AM
1Aauto's Avatar
Former Sponsor
The Metro ones are good (that's why we use them) we also do carry the origional GM ones. Agreed with Scott, if possible you should stick with the same brand seals and not mix and match.That will provide you the best protection.
T
Old May 29, 2009 | 02:46 PM
Car: 2010 2LT RS
Well that sucks. I don't know which part was replaced with aftermarket or stock. The passenger side doesn't leak at all and is sealed tight. If I don't know what it was replaced with then it would be better to buy GM for the drivers side then even if the other is aftermarket on the passenger?
Old Jun 1, 2009 | 08:43 AM
1Aauto's Avatar
Former Sponsor
Both our Metro an GM weatherstip seals well. Some of the guys have been buying the GM ones while their still available.
The Metro ones are good too, just a matter of what your budget allows and preference.
Old Oct 22, 2009 | 08:36 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates? dude i have the same problem
Old Oct 26, 2009 | 10:11 PM
Car: 2010 2LT RS
No updates as of yet. I haven't gotten around to replacing it. I will post back once that time has come.
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
