Do all third Gen's have a small gap between the hood and the front bumper
Old May 22, 2009 | 06:20 PM
91R5's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Is there suposed to be a small gap between where the front bumper meets the hood? or is it suposed to be flush.
Old May 22, 2009 | 08:00 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Re: Do all third Gen's have a small gap between the hood and the front bumper
no it's supposed to be like that to allow air to go in.
Old May 22, 2009 | 08:36 PM
Samdweezel05's Avatar
What? Open your hood and tell me if air going in between the hood and the bumper would do any good. The plastic bumbers on these cars sag and bend over time. If you have a camaro then your air comes in from the holes in the bottom of the bumper. If you have a GTA than the air comes in under the car.
Phil
Old May 22, 2009 | 08:37 PM
92 Camaro's Avatar
I am well aware it is not the only source for air lol
If you have a GTA, it comes from the hood too.
Old May 22, 2009 | 11:38 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
then how come mine is flush? lol
Old May 22, 2009 | 11:42 PM
Stephen's Avatar
Car: 87 GTA
Ummmmm......NO!
The hood vents are 100% cosmetic & allow ZERO air in.
All the air comes in front underneath & through the fog light openings (which isn't saying much).
Old May 23, 2009 | 08:31 AM
92 Camaro's Avatar
I don't know.
and stephen you didn't need to come off at me like that.
Old May 23, 2009 | 09:23 AM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
On a GTA How would you go about adjusting this gap?
Old May 23, 2009 | 09:35 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
well when i bought my gta i but a formula powerbulge hood on it. It did not sit flush like my gta hood did. so i ajusted the latch there are to screws holding it in and i lower the latch alittle. and its flush and no gap now.
Old May 23, 2009 | 09:49 AM
Stephen's Avatar
Car: 87 GTA
I don't know.
Sorry if it sounded that way. The capital letters were just for emphasis. If I had "gone off on you", it woulda been much more clearly stated.
Old May 23, 2009 | 10:15 AM
92 Camaro's Avatar
Alright. I wasn't well aware, but it didn't look obvious to me like the IROC louvers.
Old May 23, 2009 | 11:23 AM
vorteciroc's Avatar
Top Answer: 1
This is common on our cars that have had a good hit to the front end...
Old May 23, 2009 | 11:40 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I wouldn't say that. They do help to reduce the underhood temp even though they serve no purpose of cooling the engine itself.
Old May 23, 2009 | 11:43 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
i have a 90 that i bought new and there is no gap.
Old May 23, 2009 | 12:10 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
No, they don't. They are purely cosmetic.
I can't believe I'm siding with Stephen for once...
Old May 23, 2009 | 12:20 PM
Kebos86's Avatar
Car: 1986 Trans Am
Engine: 305 T.P.I
Transmission: TurboHydramatic 700R4 4 speed autom
Axle/Gears: ?
Theres going to be a very small gap for fitment, more than .125 its probably sag
Old May 23, 2009 | 12:26 PM
The vents in the hood of my GTA do serve a purpose. After I drive it really hard I can park the car and make smores over them.
Phil
Old May 23, 2009 | 01:42 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
edited
Old May 23, 2009 | 02:21 PM
Kebos86's Avatar
Car: 1986 Trans Am
Engine: 305 T.P.I
Axle/Gears: ?
There should be no gap, autos are not made with poor fitment for air. Air is pulled from underneath, the vents allow air out for circulation.
Old May 23, 2009 | 02:43 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
I stand corrected on the vents not allowing air in. I examined my spare hood in the garage and the bracing actually blocks the vents on the underside. My apologies.
If it weren't for that bracing they would be functional though.
Old May 23, 2009 | 05:34 PM
musclecar201's Avatar
Car: 87 Camaro
Engine: 2.8l V6
I also have this problem on my 87 camaro. The bumbers are brand new so is there a way I can shim up the bumper to solve this?
Old May 23, 2009 | 06:49 PM
91R5's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Thanks, that makes sense I really think my car was in an accident because its like 3 differnt shades of green. I am going to try and adjust the latch on the inside.
Old May 24, 2009 | 02:57 AM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
EVERY car i've ever seen has at LEAST 1/4inch gap between the front bumper and hood. Even factory original cars. Check it. This is a factory original car, no body work performed and this is how much gap is between the bumper and hood.
Even this FIREHAWK(The most bad azz of bad azz f-bodies has the gap)
Old May 24, 2009 | 09:21 AM
I think the gap they were all talking about was more about the hood sticking up higher than the bumper, not the bumper further forward then the hood.
Phil
Old May 24, 2009 | 10:29 AM
Kebos86's Avatar
Car: 1986 Trans Am
Engine: 305 T.P.I
Axle/Gears: ?
Perfect Gap
I believe this is the standard gap were looking for.
Attached Thumbnails Do all third Gen's have a small gap between the hood and the front bumper-gap.jpg   Do all third Gen's have a small gap between the hood and the front bumper-hood-gap.jpg
Old May 24, 2009 | 10:42 AM
Car: 1990
Axle/Gears: stock
Re: Perfect Gap
you are a very funny man.
i bought a set of hood scoops from a t/a to use on my camaro because i did not want some huge bump in the middle of my hood.
but i have bought 7 new f bodies t/a and camaro's and not one of them had anything but a good fit on the hood. you could not even put a screw driver under them. they are made to fit tight so they cant have the hood lifted by bad people.
my current one is 19 years old and still no gap.
Old May 24, 2009 | 10:53 AM
Stephen's Avatar
Car: 87 GTA
Re: Perfect Gap
That is how mine is, when it popped & only the safety catch holding it down.
When it is CLOSED & securely latched, my hood is FLUSH.
The small gap on the left side, was caused by hitting a deer & the front bumper cover being pushed down. That has been fixed since and it now as flush as the drivers side.
Old Jun 16, 2009 | 10:38 PM
SLOWMARO355's Avatar
That just happen to me, but mine was hit in front. Its about 1/2" Gap. Im Going to put the bra on it.
Old Jun 16, 2009 | 10:51 PM
Irocz28NCHS's Avatar
Car: 1986 Irocz28
Engine: 305 tpi
Axle/Gears: stock
mine has an aftermarket hood with this problem but i think its just because its fiberglass it doesnt seem to match up perfect but its very close.
Old Jun 16, 2009 | 11:09 PM
Car: 1990
Axle/Gears: stock
strange stephen but i got the ta hood vents and they are open to the air and they let air in and out.
and my hood closes good and tight and it was bought by me in 90.
but i did not put mine where the bracing would distupt the flow.
Old Jun 16, 2009 | 11:10 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Perfect Gap
Old Jun 16, 2009 | 11:12 PM
Stephen's Avatar
Car: 87 GTA
I'd love to see pics of the bottom of your hood, under the vents then. Because the inner structure makes them 100% decorative.
Old Jun 16, 2009 | 11:17 PM
Stephen's Avatar
Car: 87 GTA
How? There is no opening to allow air to transfer & carry the heat out.
Old Jun 16, 2009 | 11:18 PM
Stephen's Avatar
Car: 87 GTA
Old Jun 16, 2009 | 11:20 PM
Stephen's Avatar
Car: 87 GTA
Phil
No...They DON'T. Not stock. Are is inner bracing modified?
Old Jun 16, 2009 | 11:27 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I have a 92 that has never been hit nor has the hood ever beeen off the car and I have no gap. The air enters from underneath.
Old Jun 16, 2009 | 11:45 PM
Car: 1990
Axle/Gears: stock
the body shop is putting them in. had to take that under cover off and find a place without all the bracing. they are making a brace that just holds them in.
the rear side vents actually let hot air out and the front ones let it in. but the front are also going to feed into hose for the tpi but that still needs building. got so many small projects going on that nothing is actually getting finished.
maybe 6 months and i will rent a garage, take everything off and out - repaint everything and drop the new motor and trans in.
should take about a month to do. cant paint there so i will have to tow it back and forth to the paint booth but at least no one will touch it as it hardens. but i can sand there.
im lucky to have friends and family that will help.
Old Jun 17, 2009 | 11:28 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The word is bumPer people!!! Sorry, had to get that off my chest. I see this on many forums and can't understand how this is misspelled by auto enthusiasts.
The original poster asked about the gap and I believe he has a Camaro so the difference in Firebird gap is completely different and understandable since the front end is at the same angle and is a continuation of the hood design. The Camaro has a definite drop off from hood to bumper cover, but the gap should be non existant. Here's a pic of mine. Not sure why they gap differently, but I would guess the hood adjustments are wrong or the car has been in a wreck and not put back to spec.
Old Jun 17, 2009 | 12:34 PM
KnottyBuoyz's Avatar
Car: 87 IROC-Z
Engine: 5.7 TPI
Axle/Gears: Not sure, gotta look it up
My '87 has approx. 160,000 more miles on it than Scottmoyer's '87. You can see a small difference in the hood/bumper gap but not much. I would venture a guess that the front clip sagging due to damage or the underlying structure rusting out would lead to a bigger/uneven gap in this area.
Old Jun 17, 2009 | 03:47 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Mine really had a gap. It still does a little but they are adjustable. You have to adjust them at the Healight bar. I dont know if thats the correct term but I loosened my bolts and lifted up on it. If you look there is tolerance for adjustment. Mine has been hit so I cant get it perfect but its way better than it was. Look up my post in "Hood Gap" . I believe thats what it is.
Kevin
Old Jun 17, 2009 | 04:48 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I have a nice gap.. 1/2" atleast!
But when you're lining up new fenders, twisted hood, Formula front end from another car while keeping the doors in their original places, not everything comes out perfect.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
LittleFranks
Aug 20, 2015 03:55 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
