Removing Antenna
Old May 27, 2009 | 04:24 PM
xChevy350x's Avatar
Car: 91' Camaro RS
Removing Antenna
Swapping fenders. One has an antenna the other doesn't. I unscrewed the actual antenna but cannot figure out how to get the part that holds it on out. Special tool?
Thanks!
Old May 27, 2009 | 04:51 PM
UDAMON's Avatar
Car: Mazda Protege5
Re: Removing Antenna
the top piece just unscrews. i think they may make a tool to fit the four small slots in that piece but you can use channel locks but you may want to wrap it in a towel to avoid scratching it.
Old May 28, 2009 | 09:22 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
I usually end up cutting the nut off as here in MN they are corroded on pretty good. Replacements are cheap and easy to find. (the nut)
Old May 28, 2009 | 09:46 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
Thanks!
The base has a long bracket on it that bolts somewhere down in the fender. Can't quite remember where. PITA to get to though.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
scottmoyer
Sep 7, 2015 07:06 PM
