1990 trans am gfx on 86 base need help
Old May 27, 2009 | 07:00 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
i need help with the side gfx pieces. i took the plastic outside piece off then there was a bracket under it. but then there was a bracket mounted to the rocker panel that i dont know how to take off. my guess was under the trim and carpet but i want to make sure
Old May 27, 2009 | 08:27 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: 1990 trans am gfx on 86 base need help
Yup, behind the rear passengers arm rest plastics. When you take that piece off, there will be 1 speed nut behind it, its kind of low, in a square shaped hole. Get a flashlight, it can be hard to see.
Old May 29, 2009 | 02:35 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
ok great is that the only one holding it on? because it goes along the whole rocker panel
Old May 29, 2009 | 08:47 PM
Nope, theres more. Open your door, look down and youll see its held on with screws along your sill plates. Also, crawl under the car and there are small screws lined up across the bottom, then pull part of your inner fenderwell off (The plastic piece) and there will be 2 bolts that mount them to your fender, than it should fall off.
If your planning on re-using the gfx, be sure th remove the metal strip thats hidden under them, you need it to re-mount them.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Dialed_In
Aug 20, 2015 01:45 PM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
