Help. What do I need to do.....
Old May 30, 2009 | 06:36 PM
KnottyBuoyz's Avatar
Car: 87 IROC-Z
Engine: 5.7 TPI
Axle/Gears: Not sure, gotta look it up
I need to do some welding on the body. What should I disconnect before I start? Battery is out of the car on the charger. What about the ECM or other electronics?
IIRC the ECM on an '87 IROC is behind the dash on the passenger side, how do you disconnect it?
Old May 31, 2009 | 01:03 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: Help. What do I need to do.....
I think the manufacturer says to disconnect any electronics "in the area" of the welding. As long as your ground is connected to the same panel you should be fine.
Old May 31, 2009 | 01:21 AM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
I've been welding up the lock cylinder holes and antenna hole this past week on my car. I didn't disconnect anything and I've had zero issues.
Old May 31, 2009 | 05:13 AM
Car: 87 IROC-Z
Engine: 5.7 TPI
Thnx Fella's.
Old May 31, 2009 | 11:28 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
I'd disconnect the alternator if your doing arc welding. My GM Nova assembly manaul says to disconnect alt and batt. So I'd assume it would be the same for our cars.
Old May 31, 2009 | 11:54 AM
Car: 87 IROC-Z
Engine: 5.7 TPI
That's easy 'nuff to do and definitely cheap insurance. Thnx.
Elephantismo
Feb 13, 2019 12:51 AM
Quzyle
Oct 15, 2015 03:35 PM
Numbah-1
Oct 2, 2015 08:27 AM
Jonas Earl
Sep 27, 2015 07:39 AM
Racerx974
Sep 19, 2015 10:16 AM
