High Rise spoiler install question
Old Jun 8, 2009 | 06:11 PM
lonesomeloser's Avatar
Car: 1983 Z28
I bought a high rise spoiler from a junkyard. It has never been installed and came with no hardware. My factory spoiler has the bolts screwed into the pedestals. It feels very solid. The high rise feels hollow. How the heck are the bolts secured into the high rise pedestals if they are hollow?
Old Jun 9, 2009 | 09:10 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: High Rise spoiler install question
Same way they are screwed into your hollow stock spoiler. You'll just need more studs. Believe me, there is enough meat at the bottom of the pedestals for the studs (actually broke one out of the spoiler when I removed it the first time).
:edit: Oh, and before you do ANY drilling or installing of hardware, take the stock spoiler off, set the high rise on there, put masking tape where the pedestals are, line up the spoiler, and mark around the pedestals for proper alignment later. Install the studs in the spoiler, and mark around those as to where to drill your holes. Trust me, if you just eyeball it, it will come out crooked and ghetto looking (the way mine is).
Old Jun 10, 2009 | 10:37 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
You will also have to weld the holes from the three piece spoiler closed. Then drill new holes for the hi-rise because they won't be the same. Don't try to just bondo the holes.
Old Jun 10, 2009 | 07:24 PM
Car: 1983 Z28
Thanks for the advice. I've got a quote from a local bodyshop to fill the holes and sand them down, add a little filler, then primer= $178.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
