92 ground efx
Old Jun 22, 2009 | 10:54 PM
DANWOOD's Avatar
Car: 85 Camaro
Engine: 2.8 ltr
Transmission: 5 Speed
Axle/Gears: ?
92 ground efx
what is used to hold door fillers on and whear can i get them any help would be grate.
Old Jun 24, 2009 | 12:54 AM
Net-Viper X's Avatar
Car: 91 Bird w/Aero Pkg - 02 T/A Col Ed.
Engine: 5.0L - 5.7L Ram Air
Re: 92 ground efx
It uses those self threading nuts, the ones that look like they are stamped from sheet metal. Im not sure on the measurements for them, but its the same size and type that holds the lower ground effects to the front fender, and the ones behind the rear wheel on the quarter panel use them too. If nothing else, you could take one of those off and bring it with you to the parts store to match it up.
Old Jun 24, 2009 | 07:55 PM
DANWOOD's Avatar
Car: 85 Camaro
Engine: 2.8 ltr
Axle/Gears: ?
Re: 92 ground efx
Thanks for reply is their a bracket on the door itself the 91-92 door filers are not like prevos years thay are flat and it looks like thay wear riveted to it .
Old Jun 24, 2009 | 08:09 PM
Re: 92 ground efx
The car I own is a 91, so all the details I put down should be the same on yours. The bracket is mounted into the ground effects and has a series of posts sticking out of it to screw the nuts onto. The door itself has a row of holes along the lower portion for the posts to go into, the door has no bracket. You will need to remove your inner door panel to get the nuts off to remove the ground effects. Also there are a couple of acorn nuts on each end of the door that hold the ends of the ground effects on.
Old Jun 24, 2009 | 08:28 PM
DANWOOD's Avatar
Car: 85 Camaro
Engine: 2.8 ltr
Axle/Gears: ?
Re: 92 ground efx
Thanks for help my door pices did not come with those pices.I am in canada do you have any pics of them or do you know whear i can get proper door fillers
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
Thaney9
Oct 15, 2015 06:37 AM
lewandom
Oct 1, 2015 08:15 AM
